I have ASUS laptop FX507 when i plug-in the charger nothing happens or the amperes not even raising up it stays to 19.5v(SETTINGS). I decided to disassemble the back case to check the voltages first. I found out that when i test the current sensing resistor for voltage it was fluctuating voltages(3volts to 5v then loop), i checked the voltages of the BQ24800 Battery Charge Controller:..i started with the pin 1 and the results are:
1. 3.5v to 3.9v
2. 3.5v-3.9v
3. 0.3v-1.4v
4. 0.3v-1.2v
5. 0v
6. 2.6v
7. 0v
8. 0v
9. 1.6v
10. 0v
11. 0.04v-1.1v
12. 0.2v- 1.2v
13. 0.2v
14. 6v
15. 0v
16. 0v
17. 0.2v
18. 0.2v
19. 0.2v
20. 0.2v
21. 0.2v-0.9v
22. 0v
23. 0v
24. 6v
25. 6v
26. 0.2v
27. 0.2v
28. 19.5v
i Need help, Any idea before i change anything or i suspect the charging IC to be replace, i test the 1st and 2nd mosfets from chrging pin it is not shorted or leaky.. thank you.
					1. 3.5v to 3.9v
2. 3.5v-3.9v
3. 0.3v-1.4v
4. 0.3v-1.2v
5. 0v
6. 2.6v
7. 0v
8. 0v
9. 1.6v
10. 0v
11. 0.04v-1.1v
12. 0.2v- 1.2v
13. 0.2v
14. 6v
15. 0v
16. 0v
17. 0.2v
18. 0.2v
19. 0.2v
20. 0.2v
21. 0.2v-0.9v
22. 0v
23. 0v
24. 6v
25. 6v
26. 0.2v
27. 0.2v
28. 19.5v
