ASUS FX507v No Power
  • noipi
    • Aug 2017
    • 70
    • Singapore
    I have ASUS laptop FX507 when i plug-in the charger nothing happens or the amperes not even raising up it stays to 19.5v(SETTINGS). I decided to disassemble the back case to check the voltages first. I found out that when i test the current sensing resistor for voltage it was fluctuating voltages(3volts to 5v then loop), i checked the voltages of the BQ24800 Battery Charge Controller:..i started with the pin 1 and the results are:
    1. 3.5v to 3.9v
    2. 3.5v-3.9v
    3. 0.3v-1.4v
    4. 0.3v-1.2v
    5. 0v
    6. 2.6v
    7. 0v
    8. 0v
    9. 1.6v
    10. 0v
    11. 0.04v-1.1v
    12. 0.2v- 1.2v
    13. 0.2v
    14. 6v
    15. 0v
    16. 0v
    17. 0.2v
    18. 0.2v
    19. 0.2v
    20. 0.2v
    21. 0.2v-0.9v
    22. 0v
    23. 0v
    24. 6v
    25. 6v
    26. 0.2v
    27. 0.2v
    28. 19.5v
    i Need help, Any idea before i change anything or i suspect the charging IC to be replace, i test the 1st and 2nd mosfets from chrging pin it is not shorted or leaky.. thank you.
  • mon2
    • Dec 2019
    • 14239
    ACDRV pin #4 is not boosted to the expected ~25v so there is a fault in the power path.
    The DCin mosfets are still suspects. Remove all power. Meter in resistance mode.
    Measure each of the DCin mosfets:
    source / drain
    source / gate
    gate / drain
    Post each measurement. Start with the 2nd DCin mosfet (as per sticky above on charger circuits by piernov).
    • noipi
      • Aug 2017
      • 70
      • Singapore
      source / drain
      source / gate
      gate / drain
      thank you for the very fast reply..i will test today what you mention. i will update later today.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Resistance to GND on Current Sensing Resistor?
        • noipi
          • Aug 2017
          • 70
          • Singapore
          source / drain
          source / gate
          gate / drain
          Both DC-in MOSFET first and second got high resistance ranging Kohms to Mohms when reading for source/gate ; gate/drain. no low resistance got from this side and around the Charging ic mosfets..
          • noipi
            • Aug 2017
            • 70
            • Singapore
            i try to read the resistance to ground on Current sensing resistor is 20Mohms, seems to be good.
            • noipi
              • Aug 2017
              • 70
              • Singapore
              this time trying to test all mosfets and capacitors that is shorted...motherboards seems so clean no sign of burnt or bad components...still checking this time.
              • mon2
                • Dec 2019
                • 14239
                post the requested measurements.
                • noipi
                  • Aug 2017
                  • 70
                  • Singapore
                  here is the Readings of the DCIN mosfets before the Current Sensing resistor
                  the first dcin mosfet measure by resistance mode:
                  source/drain 8.8Mohms (probe RED BLK)
                  source/gate 1.3Mohms (probe RED / BLK)
                  gate/drain 14.34Mohms (probe RED / BLK)
                  the 2nd DCIN mosfet measure:
                  source/drain 7.8Mohms (probe RED BLK)
                  gate/drain 14.17Mohms (probe RED / BLK)​
                  • noipi
                    • Aug 2017
                    • 70
                    • Singapore
                    tried to find SCHEMATIC diagram or boardview but i cannot see.
                    • Dcortest
                      • Oct 2023
                      • 33
                      • España
                      Maybe this can help
                      Link to boardview --> https://www.badcaps.net/forum/troubl...%CC%87ew-needs
                      • noipi
                        • Aug 2017
                        • 70
                        • Singapore
                        thank you Dcortest
                        • noipi
                          • Aug 2017
                          • 70
                          • Singapore
                          Thank you to all for the help, specially to Dcortest for the Boardview that really solve the circuit. i change the 2 mosfets that are P-mosfet and N-mostfet connected to the line of Charging IC.
                          • ethics
                            • Oct 2016
                            • 39
                            Nice job! Where did you buy them?
                            • mon2
                              • Dec 2019
                              • 14239
                              Digikey should have valid replacements. Mobile Sentrix Canada also stocks assorted mosfets.
                              Post the full part numbers of the mosfets you wish to replace.
