  • akwky
    • Apr 2025
    • czech republic
    Hi!
    Incidentally, Windows 11 have recently started auto-flashing computer BIOS in our region. Even more suspiciously, Lenovo has released a BIOS update just few days before the PC was trashed. About a week later, the BIOS update image has been oficially marked as "WITHDRAWN" by Lenovo and the update R1BUJ82W has received two patched versions, latest being R1BUJ82W_V3 at this time. See the table on the following link: https://download.lenovo.com/pccbbs/m.../r1buj81w.html
    Note, how the release notes say:
    Version 1.51 (UEFI BIOS), 1.51 (ECP)
    [Important updates]
    - Fixed an issue where BIOS Update Utility will be blocked by Microsoft "Vulnerable Driver Blocklist".
    I will choose to translate that corporate speak as "Microsoft has blocked our update to avoid bricking even more machines", hehe.
    Anyway, since I failed to find any working key combo for Crisis recovery tool (The Fn+R thing where the BIOS auto-recovers from FAT32 GPT partition), although the BIOS firmware clearly contains references to said Crisis tool, I had eventual success desoldering the W25Q128JW chip and flashing it manually.
    How to do it:
    I ordered the cheap CH341A programmer (warning - it has 5V logic, will fry the chip if used directly), and a voltage shifter (TXS0108E) to turn 5V SPI signals into 1.8V, as required. Desoldered the chip by kapton-taping the surroundings, drenching one side in lead solder (it has lower melting point) and lifting that part of the chip slightly upwards. Then rinse and repeat on the other side, until I "wiggled" it free from the motherboard. (Careful not to apply pressure unless entirety of the solder is melted, or you will ireversibly break off the PCB pads.) Cleaned excess solder with solder wick, soldered the chip into the programmer.
    Used linux with the flashrom tool (apt install flashrom) to backup the image, which was showing R1BHT77W version was installed. Probably corrupted somehow, wasn't really clear to see what was wrong. Then I used UEFItool software to extract the 16M (16777216 bytes) image from the *.FL1 image which you get from the official update binary when it extracts itself.
    Flashed the binary into the chip, soldered it back. On power up, nothing happened for several long seconds, then the Self-healing BIOS backup procedure kiced in. And it BOOTS! Yay. Had to downgrade to R1BET81W and "back" to R1BET82W​_V3, otherwise the utility would refuse (and I was stuck with older version of the ECP chip).
  • trix11
    Dell Precision T1650 MT Workstation bricked after BIOS update
    by trix11
    I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
    - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
    - Dell Precision T1650 mid tower Workstation
    - Xeon E3-1225 V2
    - 32Gb PC3-12800E RAM
    - 4Tb SATA HDD
    - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
    I see now that others have experienced like issues e.g.:
    - https://www.dell.com/community/Prec...
    10-24-2022, 10:35 PM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • lordgeny
    z490-f gaming bricked after bios update
    by lordgeny
    I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
    11-02-2023, 09:03 AM
  • Jogger9663
    Flex 5-14ITL05 Laptop (ideapad) - Type 82HS bricked after BIOS update
    by Jogger9663
    Hello all! New here, trying to fix a Lenovo Flex 5 14ITL05 laptop.
    TL;DR: How do you connect a programmer to a "leg-less" SPI Flash chip? Model: Winbond W25R256JVEIQ on a board with part number 5B21B33119.
    Attached are photographs of the board for context. One is of the SPI chip close-up, the other is of the full board with the chip highlighted.
    I have a Lenovo Flex 5 14-ITL05 with the following symptoms following a BIOS update:
    • Black screen / no display
    • Caps lock indicator stuck ON
    • Power LED blinking
    • FN Lock key on at boot, but can be toggled
    12-14-2022, 02:12 PM
