Acer TMX314-51 laptop battery problem
  • ahmarzo
    • Mar 2015
    • 171
    • india
    I have acer laptop tmx314-51 with part no 6050A3020501.
    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
    The schematic is not available for this motherboard help me solve this problem.thanks
  • mon2
    • Dec 2019
    • 14427
    Check battery mosfet @ Q60012.
    Remove all power. Meter in resistance mode.
    Measure:
    source / drain
    source / gate
    gate / drain
    Post each measurement.
    • ahmarzo
      • Mar 2015
      • 171
      • india
      Sorry for late reply
      Drain to source is 440 ohms
      Drain to gate shows 3 mega ohns
      Gate to source shows 3.5 mega ohns
      • mon2
        • Dec 2019
        • 14427
        Way too low for a good mosfet. Flux and remove this mosfet and test if the mosfet still has the same values. Each measurement must be hundreds of K ohms or higher. Otherwise, replace this mosfet.
        • serious_electron
          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
          by serious_electron
          Hello Everyone!
          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
          06-28-2025, 02:57 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • ipatch
          dell inspiron 5567 laptop battery lipo WDX0R
          by ipatch
          recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
          1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
          2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
          got the computer...
          04-02-2023, 04:45 PM
