MACBOOK A2159 820-01598 FAN SPEED
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Hello everyone. It works very slowly and the fan spins very fast. The touchpad was flooded. I replaced it but the MacBook is still very slow and the fan spins at high speed. Resetting and bypassing SMС does not help! Please tell me what to look for.
  • mon2
    • 14172
    Thermal sensors in trackpad - most likely. Lacking proper communication with the smbus based sensors will throttle the cpu speed and cause high fan spin. Inspect all but trackpad is a suspect.
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      I installed the board in another case but the problem remained. I suspect that the problem is somewhere in the smc. The board is in perfect condition, there are no signs of moisture.
      • mon2
        • 14172
        Measure the voltage to ground for the following pins:
        I2C_THMSNS_SCL_R1
        I2C_THMSNS_SDA_R1
        I2C_THMSNS_SCL_R2
        I2C_THMSNS_SDA_R2
        The above SMBUS pins lead to the actual thermal sensors themselves which must be inspected.
        Review
        U5850
        U5870
        Each of the thermal controllers (above) are linked to individual transistors that must also be reviewed. If any of the above parts / communication lines are missing, you will have the observed result.
        • kenzo2
          Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
          by kenzo2
          I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
          I need dump file MACBOOK PRO A2159
          TSB4232(256)
          TSB4229(256)
          Thanks​
          01-11-2025, 04:18 AM
        • mferna14
          Password removal on MacBook Pro A2159
          by mferna14
          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
          05-13-2025, 04:16 PM
        • awe126
          Macbook Pro 16" A2485, 820-02100, battery service recommended, fan full speed, doens't charge
          by awe126
          Hello all,
          I bought a Macbook Pro 16" M1 Pro, A2485, 820-02100, which working flawlessly but not charging. I thought battery needs to be replaced but then started reading and it seems that problem will be in motherboard.
          Battery sign has cross sign and MacOS can't read battery stats. Fans are full speed but can be set down via Fancontrol software.
          I did start digging into in and found out below:
          Diode mode:
          SMBUS_BATT_SCL: 0.529
          SMBUS_BATT_SDA: 0
          SMBUS_BATT_SCL: 1.795V
          SMBUS_BATT_SDA: 0.948V
          Can anyone help...
          03-27-2025, 12:23 PM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • kleung
          Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
          by kleung
          I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
          On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
          I have tested and there is continuity between the 4 wires pins and the circuit board.
          That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
          12-07-2024, 01:45 AM
