No display on HP 17-cp0385nd
  • JeroenRood
    • Sep 2021
    • 3
    • Netherlands
    I need some assistance or advice.
    I have a laptop for repair with no display.
    HP 17-cp0385nd
    prod id : 538h5ea#abh
    motherboard : SPS:M51689-601 or 17n_AMD_FP6
    After powering on, the backlight is switched on and the CPU fan spins (variable speed), but nothing on the screen.
    If I reset the BIOS (remove batterypack), I get a message on the screen that the cmos was reset "Press Enter to continu."
    After pressing enter, I only get a blank screen again.
    I used the BIOS recovery (Win key + B) from a USB-stick and that works fine with everything on screen. BIOS is reflashed, latest version from HP.nl site.
    Laptop reboots after it's finished, the cmos was reset message appeared again, pressing enter to contine, and a blank screen again.
    Powerswitch led is on, capslock is not flashing.
    Removed all non essential components, fitted different memory, makes no difference.
    Does anyone have a suggestion, beside replacing the whole mainboard?
    Regards, Jeroen.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    Yesterday, 02:22 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
