No display on HP 17-cp0385nd
  • JeroenRood
    • Sep 2021
    • Netherlands
    I need some assistance or advice.
    I have a laptop for repair with no display.
    HP 17-cp0385nd
    prod id : 538h5ea#abh
    motherboard : SPS:M51689-601 or 17n_AMD_FP6
    After powering on, the backlight is switched on and the CPU fan spins (variable speed), but nothing on the screen.
    If I reset the BIOS (remove batterypack), I get a message on the screen that the cmos was reset "Press Enter to continu."
    After pressing enter, I only get a blank screen again.
    I used the BIOS recovery (Win key + B) from a USB-stick and that works fine with everything on screen. BIOS is reflashed, latest version from HP.nl site.
    Laptop reboots after it's finished, the cmos was reset message appeared again, pressing enter to contine, and a blank screen again.
    Powerswitch led is on, capslock is not flashing.
    Removed all non essential components, fitted different memory, makes no difference.
    Does anyone have a suggestion, beside replacing the whole mainboard?
    Regards, Jeroen.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • LEONARDO DE FREITAS
    Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
    by LEONARDO DE FREITAS
    Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
    04-18-2025, 09:58 AM
