ipad air 9th gen a2602 not powering up after charging port replacement
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i'm new to fixing ipads. i've replaced a few ports but i've not done any other troubleshooting so i'm trying learn more. What voltage should read on the battery terminal if the battery isn't connected but the charging cable is connected? i'm getting a reading but it's not stable
  • mon2
    • Dec 2019
    • 14659
    Hi.
    1) Highly recommend the 'Qianli Tail Tester' tool which can be used to quickly confirm the USB-C and lightning ports on these devices.
    https://www.aliexpress.com/item/1005001463633327.html
    https://www.mobilesentrix.com/ibridg...-tester-qianli
    * cheaper to buy through Mobile Sentrix
    2) The suspect for your case is the replacement charging port. In the absence of the above tool, you can test each soldered pad on the flex pcb in DIODE mode. Remove all power. Meter in diode mode. Red meter probe, yes RED to ground. Black meter probe to the point to measure. The above tool does the same but in a few seconds and to us, is priceless.
    The concern is if each such pad is truly mating with the PCB pads to complete the connection. Respectively, you may not even have power going onto the logic board. Approach with caution as the parts are very very small. Not our favourite repair jobs but we do a few here and there.
    • kjchatman
      • Dec 2012
      • 213
      • united states
      i'm sure that i put the charging flex cable on with accuracy. what should the voltage be on the battery terminal with out a battery attached?
      • mon2
        • Dec 2019
        • 14659
        What is the voltage you are observing at the battery connector (without the battery)?
        What is the current draw of this logic board with your power supply? Is the power supply cycling? Do you have a thermal camera?
        • kjchatman
          • Dec 2012
          • 213
          • united states
          3.8v on the battery terminal. it' barely drawing any current at all. .060 amps
          • kjchatman
            • Dec 2012
            • 213
            • united states
            a lot of the pins that connect to the charging flex cable aren't connected. they read as OL in diode mode to ground. would that be a charging IC issue?
            • mon2
              • Dec 2019
              • 14659
              Yes. As mentioned in post #2.
              • kjchatman
                • Dec 2012
                • 213
                • united states
                1614a1 ic?
                • mon2
                  • Dec 2019
                  • 14659
                  No. Based on my experience, the small pads on the flex cable do not mate with the logic board after alignment. Suggest to flux this entire flux pcb and then touch each pad to force the solder to melt and create a fresh joint.
                  There is a really good video from Alex on this - let me see if I can find and link it here. Suspecting this replaced flex cable as the root cause unless proven otherwise.
                  The 'tail' tester from Qianli is gold here for verification of the replaced cable.
                  Alex's video (also voice of the Aardvark cartoon):
                  https://www.youtube.com/watch?v=qeT-FdvYyxg
                  (tests both USB-C and Lightning)
                  Click image for larger version  Name:	IMG_4424.jpg Views:	0 Size:	813.0 KB ID:	3605759
                  • kjchatman
                    • Dec 2012
                    • 213
                    • united states
                    but i removed the flex cable to be sure and those pads are still reading OL in diode mode
                    • mon2
                      • Dec 2019
                      • 14659
                      I will suggest to review the schematic and boardview files of other ipad models with similar charging cables. Such documentation will offer diode mode readings for the charging port. Use the values to gauge the status of your case. It may very well lead down to need to replace the tristar part on your ipad. There are many variations of this tristar part and they appear to be available at least on Aliexpress. You can also check Mobile Sentrix (VA for you; Toronto for Canadians). Mobile is often at the same or even lower than Aliexpress pricing for many parts. OL usually means that the line is floating / is open circuit.
                      To confirm, you have read meter lead to a known good ground contact; black meter lead to the point to test.
                      Always triple check. I personally serviced a macbook A1932 which I will document in another thread. 2 local stores said it cannot be fixed and the motherboard was defective. Almost ran into the same conclusion from the client's feedback but after a bit of debugging, the macbook is working and the root cause was a shorted cap on a remote audio board. Needle in a haystack. Respectively, even though this ipad is not well documented, engineers like to borrow from proven designs so we too can learn from other ipad models.
                      • kjchatman
                        • Dec 2012
                        • 213
                        • united states
                        i ordered that Qianli Tail Tester for the future but i don't think this one has a problem with charging now that i've replace the charging flex cable again. It still doesn't power up but it's probably a pmic issue since the power button doesn't have 3v
                        • mon2
                          • Dec 2019
                          • 14659
                          The current draw will be very helpful. Would you have a thermal camera? If yes, hunt for any shorted parts.
                          • kjchatman
                            • Dec 2012
                            • 213
                            • united states
                            i have a thermal camera that i use all the time to do repairs but this board isn't drawing any current
                            • mon2
                              • Dec 2019
                              • 14659
                              So stuck @ 5v 0A current draw?
                              • kjchatman
                                • Dec 2012
                                • 213
                                • united states
                                yes
                                • mon2
                                  • Dec 2019
                                  • 14659
                                  Perhaps should have done this sooner but from a quick Google search, found the following compatibility list. The same cable is also used on ipad7; ipad8 as well as your ipad9.
                                  Proceed to study the pinout for this charge cable using the available schematics from ipad7 or ipad8. Locate the VBUS pin(s) from the charger to the logic board. Also locate the ground.
                                  Then remove all power / no battery. Meter in diode mode. Touch your meter probes together and should have a tone beep.
                                  Touch one probe onto the ground of the flex cable you have soldered (at the PCB pads) and other probe to metal shield on the board. You must hear a tone beep.
                                  Next, red meter probe, yes red to metal shield. Black meter probe onto the vbus pad(s). You must have a valid measurement here - not 'OL'. If you see 'OL' - the pad on your charging port cable is NOT soldered to mate to the bottom ipad port pad. Been there, done that and killed far too much time (the first time doing the same repair). Flux the crap out of it (50% of what Louis shows in his videos) + heat that pad up good.
                                  Repeat to test in DIODE mode using the same method till you have a valid reading for each pad that is connected to something on the board. If 'OL' = the pad is floating.
                                  Click image for larger version  Name:	vbus.png Views:	0 Size:	30.8 KB ID:	3607283
                                  Click image for larger version  Name:	same_cable.png Views:	0 Size:	25.4 KB ID:	3607281
                                  • GeirAndersen
                                    iPad .pcb file collection
                                    by GeirAndersen
                                    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                    IPAD COLLECTION 1
                                    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                    12-09-2024, 09:28 AM
                                  • badboyzzz
                                    A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                                    by badboyzzz
                                    I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                                    12-28-2024, 02:11 PM
                                  • coasterghost
                                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                    by coasterghost
                                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                    System Hardware:
                                    Processor: AMD Ryzen 7 PRO 5850U
                                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                    09-08-2025, 10:46 PM
                                  • thesame
                                    Lenovo TB-X605F fake charging after charging connector replacement.
                                    by thesame
                                    Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                                    04-03-2024, 03:14 AM
                                  • waterchill
                                    Apple iPad Pro 12,9" 4Gen no charging, but working fine
                                    by waterchill
                                    Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
                                    So I started to replace this parts:
                                    - replaced usb-c port -> no result
                                    - replaced battery -> no result
                                    - replaced usb-c chip CD3217B12A -> no result
                                    - replaced 343S00326 -> no result
                                    - replaced 343S00327 -> no result
                                    - replaced 343S00328 -> no result
                                    I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
                                    04-30-2024, 05:37 AM
