A2941 Macbook air 15” - 5V 0a
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    ok that make sense.
    Anyone any idea what can cause 5V 0.00A (sometimes it jumps to 0.01, 0.02, 0.03A) I tried thermal camera but this is not showing anything.
    • mon2
      • 14660
      Insert this meter in series. Then test again. Show a pic of how you are testing. Be sure the meter is bidirectional use design. Some require the meter to be mated with the power adapter and then the usb cable powers the logic board. If truly at 0 amps, there is no load. Pretty sure the meter is not being used correctly.
      • obelix24
        • Jun 2023
        • 291
        • Slovakia
        See attachments. In screenshots i left everything connected (trackpad, keyboard, battery) but even with everything disconnected (just bare board) it behaving same. Ampmeter is connected to genuine apple power adapter (96W)
        • mon2
          • 14660
          Remain to test with the port with the 20mA which is still very low.
          Remove all power. Meter in resistance mode. Measure the resistance to ground of every inductor that you see onboard. Report any suspected shorted rails.
          This case will be difficult since there are no schematics available (yet).
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            I will meassure. As i mentioned before schematics and boardview files can be used from 13” macbook air m2
            • mon2
              • 14660
              Ok. Really curious on this case. Hope we can make some progress.
              • khaahk
                • Dec 2013
                • 812
                • Estonia
                #27
                If the PPBUS_AON is still 85ohms then it is too low. I had also 5V on USB-C and similar resistance on PPBUS_AON, in my case the problem was Q5800. After changing it 20V appeared. I don't have the machine anymore to make measurements though.
                • obelix24
                  • Jun 2023
                  • 291
                  • Slovakia
                  #28
                  in diode mode
                  PPBUS_AON - 0.435
                  PPBUS_3​V3S2_VIN - 0.436
                  PPBUS_5VS2_VIN - 0.435
                  PP3V3_AON - 0.718
                  PP3V8_AON - 0.340
                  PP5V_S2 - 0.130
                  PPDCIN_USBC_AON - 0.157
                  PPHV_INT1_AONSW - 0.157
                  PPHV_INT0_AONSW - 0.157
                  PPHV_INT5_AONSW - 0.157
                  • mon2
                    • 14660
                    PP5V_S2 - 0.130
                    Diode mode is showing a lower than usual forward voltage drop. Now, switch to resistance mode on your meter.
                    Measure the resistance to ground on PP5V_S2. Post the resistance in ohms. Suspecting that the laptop was hit by some USB related transient which has led to the USB load switch or TVS ESD diodes being nuked.
                    • obelix24
                      • Jun 2023
                      • 291
                      • Slovakia
                      #30
                      resistance on PP5V_S2 is 108 ohms.
                      • obelix24
                        • Jun 2023
                        • 291
                        • Slovakia
                        #31
                        any idea ?
                        • obelix24
                          • Jun 2023
                          • 291
                          • Slovakia
                          #32
                          Will injecting voltage show something ?
                          • khaahk
                            • Dec 2013
                            • 812
                            • Estonia
                            #33
                            You'll have to inject and see, there is no way to tell it in advance.
                            Are some voltages present if you are saying that PPBUS is 12V, 3v8aon, 3v3aon?
                            If the board was working at first and stopped after waiting for the screen then water damage got worse. (was battery connected during this time?)
                            Visual inspection of the damaged areas not helping?
                            • obelix24
                              • Jun 2023
                              • 291
                              • Slovakia
                              #34
                              Yes it was working and in the time waiting for new screen i let battery connected as i tested this macbook without screen with external display. Then put to shelf.
                              i noticed one thing when i try different amp meter i can see
                              one port is 5v 0a 9999.9ohm
                              but on the other port there is 5v 0.02-0.03a and ohms are sometimes 185ohms and sometimes it jumps to 9999.9ohm (on ampmeter) see attached photo
                              does this mean anything ?
                              • khaahk
                                • Dec 2013
                                • 812
                                • Estonia
                                #35
                                As the battery was connected some electrolysis process continued and now some connection is lost somewhere. Only visual inspection can help. Critical are parts which have positive voltage all the time and are important (ie boost circuit on smps). You did not answer about the PPBUS or AON voltages, are they present or not, which ones if any? Are there any differences if connected to the port which uses 0.02A?
                                If you are asking about the resistance shown on usb-c tester then it is probably just calculated from voltage and current information.
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • reformatt
                                  by reformatt
                                  07-31-2025, 08:37 PM
                                • MagJ_
                                  MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                                  by MagJ_
                                  Hello Everybody,
                                  I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                                  10-09-2024, 02:51 PM
                                • sofles
                                  Macbook Pro 16" A2141 screen artefacts, kernel panic
                                  by sofles
                                  Hi there.
                                  I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                                  I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                                  Now situation looks like this, If...
                                  02-05-2025, 05:05 AM
                                • ahoonid
                                  MacBook A1990 vertical stripes on external screen
                                  by ahoonid
                                  Hey everyone,
                                  I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                  The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                  Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                  06-20-2025, 08:54 AM
