Are these mosfets the right ones?
  • DeXXter
    • Aug 2023
    • 112
    • Chile
    Hello, I got this motherboard HP G3M dag3mmb2ca0 for repair and I found out that it was a mess, short on cpu's vcc_core and 3vs5 (shorted pch) and a lot of moved capacitors, apparently one of the cpu's dual mosfet got shorted and someone injected 20v directly to it and I don't know if these mosfets are the ones that belong on this motherboard QA3111, I had another victus with i5 (this has i7) and it has different ones (NTMFD1D6N03P8-D).
    Someone who have worked on this motherboard maybe know if these are the right ones? I guess they are, but better be sure, besides they seem moved and not well placed, luckily apparently the gpu is not dead :,)
    Click image for larger version  Name:	HP VICTUS G3M.jpg Views:	0 Size:	261.8 KB ID:	3598022
  • mon2
    • 14659
    These look like the CPU mosfets based on the vicinity of their locations relative to the CPU. Each part should be reviewed for shorts, etc. Worked on by Stevie Wonder?
    As suggested by piernov, if replacing the mosfets, the mosfet drivers should also be replaced. All or nothing. Suggest highly to review against a known good board / schematic to fix up this region.
    Even the fuse in the lower right side ('P') is with a solder blob. At least one of the CPU mosfets is skewed too far to the right and most likely shorting.
    Aside from the above, do measure the resistance to ground of the CPU which may or may not be dead from this failed rework attempt. Suspecting they were on the hunt for a shorted capacitor, etc. when the short may very well be the CPU itself.
    • DeXXter
      • Aug 2023
      • 112
      • Chile
      Indeed my friend, the cpu got shorted sadly, it has 0 ohm to ground on vcc_core (this cpu should have like 50 ohm), I found solder traces on the main current sensor, so probably when the third mosfet on the middle got shorted (I know this is the one) this guy injected 20v in there. Which I kinda understand, but honestly I have no idea how the 3v rail got shorted (3v power supply is fine), and i found like 20 capacitors and a few more inductors and current sensors taken aside (like the capacitors on the picture) on that line, I guess he was trying to find a "shorted cap"... I bought this motherboard for parts, wanted the cpu for a broken laptop that I have, but no luck this time, at least the gpu and vram memories seems fine.
      Thanks for the answer tho, I don't think it's worth it to try to fix this, but at least I'll try to eliminate the shorts
      • mon2
        • 14659
        3V is used by the PCH section of the CPU. For giggles, you can remove the malformed mosfet off the board and test the CPU resistance again. Perhaps it is this mosfet that is raising this short condition (cross your fingers). A 20v injection is a killer to most parts.
        • DeXXter
          • Aug 2023
          • 112
          • Chile
          Took out the pch and the short on 3v is gone, but the one on vcc_core on the cpu remains, so cpu and pch are gone (this is the weird thing), also took out the shorted mosfet that way I have no shorts on the motherboard anymore, in theory if I replace both, cpu and pch this should work again, but it's a high risk and expensive play, I guess I will just save it in case I find another motherboard 😅
          • Yanleb
            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
            by Yanleb
            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
            D608, good
            D618 RF101L4S, good (See warning 1 below)
            D619 RF101L4S, good (See warning 1 below)
            D865 RF101L4S, shorted (See warning 1 below)
            IC464 Inverter HA MC74HC1G14, shorted...
            03-09-2020, 12:00 AM
          • modtool
            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
            by modtool
            Hi to all,
            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
            04-01-2025, 08:22 AM
          • BalkanBoy
            Dead Razer Blade 14 2022, shorted CPU?
            by BalkanBoy
            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
            I removed coil and injected 0.7V, it draw around...
            09-27-2024, 12:44 PM
          • guizmo1967
            Dell Latitude 5501 LA-H181P shorted power rail
            by guizmo1967
            This is my problem:
            Laptop: Dell Latitude 5501
            Motherboard: EDC51 LA-H181P
            I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
            I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
            I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
            I injected +1.05V - 2A...
            07-25-2023, 06:56 PM
          • kotel studios
            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
            by kotel studios
            Finally got time to fix this board up.
            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
            04-22-2025, 05:08 AM
