MacBook A2442 power cycling
  • macabook
    • Sep 2024
    • 30
    • France
    Hi, having an issue with A2442 getting 20v around 200mA cycling every 2 or 3 second, same on every usb-c Port. No water damage. PP3V8_AON is 0.100 in diode mode and 100Ohm resistance to ground. When I measure the voltage it 3.8v stable that goes on and off every 2 to 3 second. When I inject voltage it doesn’t consume much only 6mA that is not a short.
    Compared to similar broad diode mode is 0.330 and resistance in kilo.
    I don’t know what to do next ?
  • mon2
    • 14177
    Test with a known good battery.
    Test with a DFU.
    https://boards.rossmanngroup.com/thr...0/#post-113047
    • macabook
      • Sep 2024
      • 30
      • France
      Thanks mon,
      I tried a restore on DFU mode that fails with error 21, the power cycling is no more happening. I tried many times still getting error 21. According logi.wiki it's most probably a NAND issue like the case you shared on Rossmanngroup.
      • macabook
        • Sep 2024
        • 30
        • France
        The MacBook finally restored in DFU mode, it was my mistake trying to restore it while on recovery mode (blue MacBook image showing on configuratore 2). I entered DFU with keyboard combinaison and the restore successfully finished on the first attempt.
        • mon2
          • 14177
          Excellent.
          • dbuergi
            Macbook A2442 no display board 820-02098
            by dbuergi
            i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
            So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
            05-25-2025, 10:58 AM
          • dbuergi
            MacBook A2141 one USB port dead and one power cycling
            by dbuergi
            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
            04-25-2025, 11:40 AM
          • bastien
            OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
            by bastien
            It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
            This is the new database for FlexBV
            it's optimized to work with it
            by using board ID has Default name, give us the opportunity,
            to use other diode board data with sibling board or family board
            I Merged the whole data (optimal)
            A2991 A2992 M3 -> -> 2 Entries diode data M1
            A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
            A2442 A2485 A2779...
            03-18-2025, 08:03 AM
          • Constantinos
            Macbook Pro A2442 820-02098 No image but has backlight
            by Constantinos
            Hi all
            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
            Obviously, he decided against this and gave it to me so that I could have a crack at it.
            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
            08-24-2024, 09:48 AM
          • Enzo150i
            MacBook A2442 exclamation mark after oxydation
            by Enzo150i
            I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
            The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
            Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
            We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
            06-29-2025, 01:26 PM
