Apple MacBook Pro A2485 - No backlight
  • tommy97
    • Mar 2023
    • 172
    • United Kingdom
    We're working on an A2485 MacBook with no backlight after liquid damage. The damage occurred near the backlight IC (UP800). We've checked all the nearby resistors and capacitors, and everything seems fine. We replaced UP800 from a donor board.
    However, UP830 was also liquid damaged, and after cleaning, resistor RK830 came off. Unfortunately, I can't find its value, and the schematic doesn't indicate it as a critical component.
    Would anyone have insights or a way to confirm the RK830 value?
    Thanks in advance!
  • mon2
    • Dec 2019
    • 14755
    See attached. I see this as 10 ohms, 0201 resistor.
    • tommy97
      • Mar 2023
      • 172
      • United Kingdom
      I've replaced this resistor, still no backlight -
      ppluxe_lx2 - 4.8v
      LP800 - 0.250V
      PPLIXE_LX2 - PPLIXE_LX1 0.250v
      PPVOUT_LUXE_XW 0.250v
      Checked everything around UP830 on diode mode everything in range of 0.200-0.800 but LUXE_ISL_R_P/N they're 0.0 as they lead to gnd i believe?
      • mon2
        • Dec 2019
        • 14755
        What is the voltage to ground of PP5V_S2_LUXE @ RP805 (pin 1)? This is the power rail to the backlight controller.
        PP5V_S2_LUXE_VDDA ; should be ~5v
        BL_PWR_EN ; is the backlight being enabled signal?
        • tommy97
          • Mar 2023
          • 172
          • United Kingdom
          PP5V_S2_LUXE_VDDA & PP5V_S2_LUXE 5.1v
          BL_PWR_EN - Goes to 1.2v then drops to 0
          (Both checked on new and old screen)
          • mon2
            • Dec 2019
            • 14755
            Good. So the logic board is attempting to turn on the backlight but then turns it off. This could be due to an excessive current draw of this display load and is being sensed by the circuit to power it down.
            Remove all power. Measure the resistance between:
            PP3V8_AWAKE_BKLTCONN_ISNS and PP3V8_AWAKE_BKLTCONN_ISNS_R
            • tommy97
              • Mar 2023
              • 172
              • United Kingdom
              I couldn't locate either of the section on the boardview, i checked by RD966 in between leg 1&2 - Short/OL 0.01Ohm.
              isns_pp3v8_aon_blktconn_p TO isns_pp3v8_aon_blktconn_n - no connection in between​
              • mon2
                • Dec 2019
                • 14755
                Apparently there are 2 versions of boards for the A2485 chassis.
                There is:
                820-02100
                820-02382
                Which one is yours? The 820-02382 does feature this current sensor for the backlight. Appears to be present in the schematic but in the boardview for the 820-02100.
                Moving forward, with no power to the board, measure the resistance to ground of this backlight power rail. Do you have UP730 onboard? This is the LDO used to power the backlight.
                • tommy97
                  • Mar 2023
                  • 172
                  • United Kingdom
                  UP730 ​It is on the board. 820-02100-a
                  • mon2
                    • Dec 2019
                    • 14755
                    Measure the voltage of PPBCON_SW_REG from UP730 output pin # 1.
                    • tommy97
                      • Mar 2023
                      • 172
                      • United Kingdom
                      PPBCON_SW_REG - 3.3v on RP732 / Pin 1 (It is called PPBCON_AWAKESW_BKLTCONN)
                      • tommy97
                        • Mar 2023
                        • 172
                        • United Kingdom
                        Anyone?
                        • mon2
                          • Dec 2019
                          • 14755
                          Has the lid angle sensor been replaced?
                          • tommy97
                            • Mar 2023
                            • 172
                            • United Kingdom
                            No, as i'm testing it on brand-new screen and i don't want to waste a new angle sensor. I did check section next to LCD Connector PPVOUT_LUXE_XW 0.078v, is there a way and possibility to trigger screen enable signal or is too risky?
                            • tommy97
                              • Mar 2023
                              • 172
                              • United Kingdom
                              I've replaced lid angle sensor, there is no change. I've noticed that while JP600 connected laptop does not boot/no display externally.
                              • samstown
                                Apple 076-00236 Genuine Apple Data Migration Tool for MacBook Pro 2016 2017
                                by samstown
                                This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
                                Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
                                Claude...
                                05-09-2024, 02:02 AM
                              • spwoof
                                Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
                                by spwoof
                                I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
                                If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
                                10-05-2024, 08:02 AM
                              • spwoof
                                by spwoof
                                10-05-2024, 07:24 AM
                              • arahban
                                Apple MacBook A2442 faulty PMIC - Question about possible replacement
                                by arahban
                                Hello Gentlemen,
                                I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
                                I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
                                Can you please help me confirm if the U7700 can be replaced with U8100 ?
                                APL1098 is it the same as APL1096
                                Thank you very much in advanced
                                Ahmad
                                12-23-2023, 05:25 AM
                              • Loki_Fido
                                Requesting help identifying chip in Macbook Pro A2485
                                by Loki_Fido
                                Hi ya folks,
                                I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
                                It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
                                I replaced it and the SSD are fine. No more shorts.
                                But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
                                But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
                                Chip marking...
                                08-07-2025, 10:17 PM
