The final piece to the nVidia puzzle - voltage
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: The final piece to the nVidia puzzle - voltage
    It's next on the list. I have a HP G62 with onboard video coming in.
    Although i've done many of those and they have always behaved well after reballing, so i don't know whether it's absolutely necessary to undervolt it. But i will try.
    A working TV? How boring!
    • spleenharvester
      • Mar 2010
      • 921
      It's not quite like that - i'm sure the manufacturers WILL give a damn if they made a mistake in the past that cost them $200 million... I was just pointing out that there is yet another side to the big nVidia issue that very few people have investigated.
      NV were only sued because of the bumping issue being an inherent defect, that was causing far higher numbers to fail in a far shorter timeframe. While higher voltages may compound the issue, it's an example of cost vs comprimise - many chips out there won't run below those voltages even though some will. Manufacturers have been doing this since forever.
      It's similar to the copper shim vs thermal pad thing - it compounds the issue, but it is not the root cause.
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5044
        • US
        genus. fucking genus.
        • dj_ricoh
          • 2073
          I got to a g62 !
          I got it from ebay with 28£ no hdd/ram and cover.
          left it run for 15 min athen I shut it down straight away then power back and voila ! HP LOGO.
          its wait for me to get a proper fix but I`m working on a stupid asus g1s with 8600gt that **** S**T.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Intel has been doing this since forever too - see the huge overclocking headroom on all their chips - but their chips don't die because they don't lie about their power budget, and are very good at making low-power chips.
            NV's chips almost always eat more power than they say they do, which has consequences further down the road. See the Tegra 2/3 scandal, where multiple OEMs pulled out of the deal when nVidia gave them the final product - 20% over the power budget and 25% slower than they said it would be.
            Originally posted by dj_ricoh
            I got to a g62 !
            Mine's here too. I'll keep you updated.
            • mohamed.mostafa
              • Sep 2012
              • 40
              • egypt
              #26
              creative.
              • Instafixx
                Macbook A2179 820-01958
                by Instafixx
                Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                I checked the Power Sequences below and found this -
                Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                05-20-2023, 05:19 AM
              • Fernon@Repair
                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                by Fernon@Repair
                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                VCCIO voltage ok
                VCCSA Voltage OK
                VCCPLL Voltage OK
                Ram Voltage ok
                RamVTT OK
                VPP 2.5 OK
                But No Core Voltage
                and i want to this vrm ic datasheet or pinout (ISL69269)
                anyone have this ic pinout voltages?...
                06-25-2025, 07:19 AM
              • electron_jj
                Panasonic TH-L42D25A checking the PSU output voltage
                by electron_jj
                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                08-29-2021, 08:13 AM
                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                by sam_sam_sam
                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                Now...
                06-09-2024, 10:57 AM
                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                Based on Intersil's Robust Ripple Regulator...
                11-05-2024, 03:24 PM
