mapping of MemTest86 errors to a single chip
  • rumpumpel1
    • Jul 2019
    • 139
    • germany
    I would like to receive confirmation that the following considerations are correct:
    I have a Lenovo ThinkPad T490s (NM-C891) with 16GB RAM (8 chips) soldered on the mainboard.
    MemTest86 reports the following errors:
    Lowest Error Address: 0x1F97B0930 (8087MB)
    Highest Error Address: 0x1FB7B6DB0 (8119MB)
    Dividing the 16GB into address ranges per chip I get the following table:
    #1 0x000000000 - 0x07FFFFFFF
    #2 0x080000000 - 0x0FFFFFFFF
    #3 0x100000000 - 0x17FFFFFFF
    #4 0x180000000 - 0x1FFFFFFFF
    #5 0x200000000 - 0x27FFFFFFF
    #6 0x280000000 - 0x2FFFFFFFF
    #7 0x300000000 - 0x37FFFFFFF
    #8 0x380000000 - 0x3FFFFFFFF
    mapping the error addresses to chips indicates, that chip #4 is faulty.
    ordering of the chips according the schematics:
    SUB CHANNEL A: U3301 U3302 U3303 U3304
    SUB CHANNEL B: U3501 U3502 U3504 U3503 (why this strange ordering?)
    so the fourth chip would be U3304.
    Looking at the mainboard shows the following (strange) ordering:
    U3503 U3504 U3502 U3501 U3304 U3303 U3301 U3302
    So I have to replace the fifth chip from the left. Is this correct?
  • dggn
    • Aug 2016
    • 5
    • Poland
    I have the same problem with this model. Was it possible to solve the fault ? Or maybe someone had such a problem and hints ?
    • rumpumpel1
      • Jul 2019
      • 139
      • germany
      So far I have not been able to solve the problem. I have tried using hot air and cold spray to locate the defective chip, but to no avail.
      • pc_okay
        • May 2022
        • 241
        • FRANCE
        Hello don’t burn your brain for This,
        if laptop work try LENOVO Hardware Diagnostic F10, it may be more accurate.
        If not just change chips until it works and hope to be lucky !
        ps: I don’t think cold spray Will help you in that case. you may use it only to locale short because short attract current and when a lot Of current pass in a component it heat.
        good luck 😊
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • Troystain
          Help EZP2023+ updated chip database for w25q256jveq?
          by Troystain
          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
          I need to add w25q256jveq chip but I do not know what data should I type.
          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
          11-25-2024, 12:53 AM
          Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
          H8S Family / H8S/2100 Series
          Ordering codes:
          F2112TE25V F2112BG25V F2112LP25V
          The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
          CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
          As peripheral functions, each LSI of the group includes a serial communication...
          10-23-2024, 02:33 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • inck243
          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
          by inck243
          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
          The BIOS...
          07-25-2024, 09:17 AM
