hp omen 15-dh1015nl does not turn on
  • Sephir0th
    • Oct 2020
    • 1260
    Originally posted by giulio93
    Looking at the PU301 diagram i think it's a problem also having 0V at pin1 and 6. Am i correct?
    It is impossible to have voltage at Pin 2 - 5 but not at Pin 6. They all are connected together.
    But yes, the Missing Enable at Pin 12 is a problem.
    FairRepair on YouTube
    • giulio93
      • Aug 2021
      • 258
      • Italy
      #82
      In the datasheet pin6 is not connected to pin2-5
      • Sephir0th
        • Oct 2020
        • 1260
        My fault this time. Have confused the pinout with a different Controller...
        So yes, missing voltage at LX, just means the Buck converter is not working. But this was already clear, since it is not even being enabled.
        • giulio93
          • Aug 2021
          • 258
          • Italy
          #84
          I tried to inject 3.3V at the missing Enabling signal and nothing happen. The EN2 Is generated by I/O chip, correct? Of yes, how can I/O chip can generate this signal if It Is not powered?
          • giulio93
            • Aug 2021
            • 258
            • Italy
            #85
            considering the trial I did, now i order some of this chip to try the replacement way. What do you think? No changes also with the EN1 up (externally given)
            • Sephir0th
              • Oct 2020
              • 1260
              EN2 isn't generated from the EC. It is build via a voltage divider from the main power rail as source
              And the EC is for sure powered, because this is what the EN2 does, powering up the 3.3V LDO (PIN17 ) supplying the EC, except you have missed a short to GND there.
              • Sephir0th
                • Oct 2020
                • 1260
                Makes no sense to me that the controller has a problem. If there is no EN1, it is not supposed to power up the buck converter. That nothing happens from manual injection is strange though. You are sure you have excluded a short to GND on thie +3VALW too?
                • giulio93
                  • Aug 2021
                  • 258
                  • Italy
                  #88
                  I've measure all the caps around the EC chip (little doubt: the EC chip and I/O chip are the same thing, right?) and there were no voltage. I will now measure at pin17 of the EC chip and tell you the value.
                  Where is the +3VALW pin? On the EC chip or the converter?
                  • Sephir0th
                    • Oct 2020
                    • 1260
                    I don't know what you call I/O chip. The EC is the embedded controller, typically a big IC with 128 pins or in small square a BGA package
                    You ere advised to measure Pin 17 at the 3V controller, not at the EC.
                    The LX pins of the 3V controller are literally (connected to) the +3VALW.
                    Didn't you took a look to the screenshot of the schematics above?
                    • giulio93
                      • Aug 2021
                      • 258
                      • Italy
                      #90
                      PIN17 is at 0V
                      And i remeasure all the caps around the EC chip and they are all at 0V. I don't understand why you sayng the EC chip is powerd
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #91
                        PIN6 is about 20Kohm to ground (going down, i supposed couse af a charging cap)
                        • Sephir0th
                          • Oct 2020
                          • 1260
                          When you have voltage at EN2 (PIN 11) present then the (3V) LDO (Pin 17) should have power. As simple as that. If this is not true, then there is a problem (e.g. short to GND) on the LDO rail or the Main power rail is missing (again).
                          You should concentrate on that instead of randomly digging around without any structure. After 5 pages full of text it's slowly time to make some progress, you don't think so?
                          • giulio93
                            • Aug 2021
                            • 258
                            • Italy
                            #93
                            The main Power rail Is present and PIN17 Is not shorted to gnd (and also pin6 Is not shorted to gnd)
                            • Sephir0th
                              • Oct 2020
                              • 1260
                              Do us a favor share a new picture of this exact controller including the surrounding circuit. A clear and high quality close-up please. Thanks.
                              • giulio93
                                • Aug 2021
                                • 258
                                • Italy
                                #95
                                Like this? Click image for larger version
                                • Sephir0th
                                  • Oct 2020
                                  • 1260
                                  Like this?
                                  Measure resistance to GND and voltage at this cap.
                                  • giulio93
                                    • Aug 2021
                                    • 258
                                    • Italy
                                    #97
                                    Just 2.7 Ohm. you were right! So the pin17 rail Is shorted to gnd.. to find the shorted components i can inject 1V in this cap and see what goes hot, correct?
                                    • Sephir0th
                                      • Oct 2020
                                      • 1260
                                      Yes, there will most likely appear the embedded controller being shorted.
                                      • giulio93
                                        • Aug 2021
                                        • 258
                                        • Italy
                                        #99
                                        At 1V and 0,4A the EC goes up to 40°C.
                                        I don't think its normal. There Is amy chance that the coulprit Is not the EC chip but something else?
                                        • Sephir0th
                                          • Oct 2020
                                          • 1260
                                          No. Possibly something in addition. But the EC per 100%
                                            HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:44 PM
                                            HP OMEN X OMEN X by Desktop PC - 900-010 OMEN X i7-6700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN X OMEN X by Desktop PC - 900-010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-010 boardview and OMEN X OMEN X by Desktop PC - 900-010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN OMEN 870-033ng OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN 870-033ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN 870-033ng boardview and OMEN OMEN 870-033ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
