hp omen 15-dh1015nl does not turn on
  • mon2
    • Dec 2019
    • 13829
    Flip the board over and post clear pics of the area under the PUB1 charger IC. We are hunting for the DCin mosfets. These parts may be close to the DCin power connector as well.
    • giulio93
      • Aug 2021
      • 258
      • Italy
      #62
      I find the DCin mosfet, what are we looking for? The have a regular 19V in and out and 25V on the gate
      • mon2
        • Dec 2019
        • 13829
        Continue to test this power path. What are the voltages on the 2nd DCin mosfet?
        Since the gate pins are shared, the 2nd gate pin should also be the same voltage. Share the source & drain pin voltages on the 2nd dcin mosfet.
        • giulio93
          • Aug 2021
          • 258
          • Italy
          #64
          I have the DC_IN voltage on pin 31 and 32
          • giulio93
            • Aug 2021
            • 258
            • Italy
            #65
            mon2 all the values you are asking me for I already shared. I have the 19V on the 2nd dcin_mof and 25V on the gates. Now I understood we have a problem with the line on the PIN1. But without a boardview how can I find the colprut?
            • mon2
              • Dec 2019
              • 13829
              Do you still have PUB1 @ 85C?
              Pin 1? On PUB1? The voltage is in range because of the voltage divider built by the resistors which lowers the Vin of the power adapter.
              • giulio93
                • Aug 2021
                • 258
                • Italy
                #67
                No now, i don't have 85C on the PUB1 since I chenged it. I don't undestand, so 2,66 V is ok for PIN1?
                • mon2
                  • Dec 2019
                  • 13829
                  Based on the example circuit from the other vendors (Acer) - they used 2 resistors on pin 1. We are assuming that this vendor used a similar circuit. In short, Pin 1 is used to sense if the power adapter is with the proper voltage range. Often the voltage should be 2v7 or higher to gauge the adapter is ok.
                  The final test is that ACOK is being configured to a logic '1' = OK. Otherwise, this line would be parked to a logic low = '0'.
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    #69
                    The last sentence is a confirm that both PIN1 and PIN2 are ok or not. I am not understanding
                    • mon2
                      • Dec 2019
                      • 13829
                      Sorry - It is ok. Pin 1 is the (lower) voltage from the power adapter. Then Pin 2 is the ACOK output from this charger IC to announce if the Pin 1 voltage is OK or not. Since Pin 2 is a logic '1', the adapter voltage is OK.
                      If the logic board is not turning on, test each and every inductor on the board to confirm their voltages are OK. Each inductor is linked to a local power rail. If they are, review to reflash the motherboard with a known good bios image.
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #71
                        I have no power to the I/O chip and on the bios chip and so on.
                        Anyway now i will measure the voltage and send a pic of them. Are you going to be online tomorrow to continue the troubleshooting?
                        • giulio93
                          • Aug 2021
                          • 258
                          • Italy
                          #72
                          I took the measures. Without the battery plugged in I have 0V on each inductor. (che grey chocke). With battery plugged in (V_batt is 11.5) i have the 2 tension in the pics. I dont remember if i said it or not so i will say again now. The pc stops works due to a screw fell into the PUB1 zone.
                          • mon2
                            • Dec 2019
                            • 13829
                            According to elektroda, the LA-H492p schematic can be used to reference the LA-J662P.
                            Locate the following power supply ICs - these are used to power your missing bios power rails.
                            On the inductor with the 0v, measure the resistance to ground. Post the resistance value.
                            • giulio93
                              • Aug 2021
                              • 258
                              • Italy
                              #74
                              Click image for larger version  Name:	always_rails.png Views:	42 Size:	217.5 KB ID:	3629136
                              How Can I find the 2 power supply ICs? How can I recognise them? Furthermore​, if i don't remember wrong, i should check the I/O chip power before the bios chip. Isn't it?
                              Here the resistance reading of the inductors. No one reads 0Ohm or near it
                              • mon2
                                • Dec 2019
                                • 13829
                                Hunt path should be -> search for the part using the white silk screening on the PCB. So search for PU301 (as an example).
                                Plan B is to review the schematic -> review the part number -> ideally, there should be a public datasheet for the component on the internet -> download for a review. Note the topside markings from the datasheet and hunt for this same part on your board.
                                See attached for PU301.
                                • giulio93
                                  • Aug 2021
                                  • 258
                                  • Italy
                                  #76
                                  Here the V on PU301
                                  P1 0V
                                  P2 P3 P4 P5 19,98V
                                  P6 0V
                                  P9 0V
                                  P11 4,6V
                                  P12 4,6V
                                  P13 0V
                                  P14 0V
                                  P17 0V
                                  P19 0V
                                  P20 0V
                                  The other pin are GND or NC from the schem.
                                  From these measurment are we understand that this chip is not working properly or is missing some "enable" line that activates it?
                                  Thanks again
                                  • Sephir0th
                                    • Oct 2020
                                    • 1250
                                    There is almost no way for Pin 12 to measure higher than 3.3V, since this enable is directly asserted from the EC.
                                    Get used to double-check your measurements please and also try to avoid bridging pins together, depending on the thickness of your probes.
                                    FairRepair on YouTube
                                    • giulio93
                                      • Aug 2021
                                      • 258
                                      • Italy
                                      #78
                                      I swear i triple check the measures but i get wrong all 3 times. the PIN12 is 0V
                                      • giulio93
                                        • Aug 2021
                                        • 258
                                        • Italy
                                        #79
                                        Now i supposed the problem is the missing EN1, correct?
                                        • giulio93
                                          • Aug 2021
                                          • 258
                                          • Italy
                                          #80
                                          Looking at the PU301 diagram i think it's a problem also having 0V at pin1 and 6. Am i correct?
                                            HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-12-2024, 03:44 PM
                                            HP OMEN OMEN by Desktop PC - 870-128na OMEN 870 i7-6700 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN OMEN by Desktop PC - 870-265na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-265na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-265na boardview and OMEN OMEN by Desktop PC - 870-265na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN OMEN by Desktop PC - 870-240na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
