hp omen 15-dh1015nl does not turn on
  • giulio93
    • Aug 2021
    • 258
    • Italy
    ACOK is pin on charging IC and its should be high indicating presence of a valid adapter and dc-in is correct. Refer to any schematic with same ISL739 chip eg, dell inspiron 3567 15341-1 mb.
    Not having the pinout which PIN should be? And It Is a I or O per the IC?
    What should I check know?
    It Is normal to have all this PIN at 0V or 0,06ish?
    • giulio93
      • Aug 2021
      • 258
      • Italy
      I thing I find something strange.
      Here in the pics I report the V at those resistors (I think they are resistors). If I measure the resistance of the resistor inside the circuit I get 150KOhm ish. If I measure against GND the second gives me 150KOhm again but the top one gave me 0.4V!!! Is it possibile that after the smd I have a short?
      I tried to inject 1V and it takes all the A i gave (I stayed low around 0.5A) but I didnt see nothing becoming hot so i stop the injection.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        As per post#20, i've given you hint to get charging ic pinout by referring to another schematic. You need to do your homework and stop playing with voltage injection and instead focus on troubleshooting.
        Resistor needs to be measured out of circuit. Just de solder them and put it on one pd of the resistor.Now you can measure true resistance.
        • giulio93
          • Aug 2021
          • 258
          • Italy
          I am not very good in reading schematics. Anyway I found the schematic of the laptop you suggest me and to understand better what is the ACOK i look at a datasheet of a BQ735. Anyway now I measure again the pin2 and i get 2.8V, I don't know if the first reading was wrong or if something has change (most likely the firs hipotesy). 2.8V is high or still low?
          • mon2
            • Dec 2019
            • 14673
            It is a bit low but may be ok. This same voltage is used to enable / disable the mosfet @ PQ4410 using the gate pin linked to a resistor based voltage divider.
            Carefully, measure the voltage to ground of pin # 4 (gate pin) of PQ4410 with the power adapter connected.
            If this gate voltage is = ~19v (power adapter voltage) then ACOK is ok since
            * this voltage has turned on the mosfet @ PQ4405. When PQ4405 is ON (enabled), the resistor @ PR4422 mates to ground, building a resistor based voltage divider using PR4422 and PR4441.
            Together, these 2 resistors will offer a lower voltage than the power adapter voltage of 19v. Being a P-channel mosfet @ PQ4410, the gate voltage needs to be lower (than the 19v) to fully turn on.
            Without a load, the expected voltage for ACOK is ~3v9.
            • giulio93
              • Aug 2021
              • 258
              • Italy
              #26
              How can I find those mosfets and resistors on the board?
              • mon2
                • Dec 2019
                • 14673
                Typically use the boardview drawing, if one is available. If not available, locate the power connector on the board and also the battery charger IC. The DCin mosfets will be plastered between these 2 points of study.
                Look for PQ4410 mosfet. See attached.
                • giulio93
                  • Aug 2021
                  • 258
                  • Italy
                  #28
                  The DCIN mosfets are those I already measure? 19.9 on D e S and 25V on the gate?
                  • mon2
                    • Dec 2019
                    • 14673
                    What are the topside markings on this mosfet @ PQ4410?
                    • giulio93
                      • Aug 2021
                      • 258
                      • Italy
                      #30
                      If you are talking about the first 2 DC-IN mosfet they are "Nikos PK5N2ES" for the big one (the first one) and "7360" for the other one.
                      I have not the PQ4410 mark on the board
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #31
                        Can you guide me sir?
                        Please
                        • giulio93
                          • Aug 2021
                          • 258
                          • Italy
                          #32
                          Is my answer on pint about your question?
                          • mon2
                            • Dec 2019
                            • 14673
                            See attached. May be a bad pic but suggest to apply IPA alcohol and clean up with a cotton earbud or similar. Want to be sure there are no shorts here.
                            • giulio93
                              • Aug 2021
                              • 258
                              • Italy
                              #34
                              Ok I'll do It. But reguarding the previus questione? You ask me for a top marking chip. I answer to your question? Can we continue in the ACOK checking?
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                This looks almost completely "cold"
                                However, is the Main power rail present or not? The approach has almost no structure for some reason.
                                FairRepair on YouTube
                                • giulio93
                                  • Aug 2021
                                  • 258
                                  • Italy
                                  #36
                                  The 19V is present
                                  • giulio93
                                    • Aug 2021
                                    • 258
                                    • Italy
                                    #37
                                    It is normal that I have 2.8V ad the right node of the resistor (the black chip) and 0 on the left side? Measuring in resistance mode I have 0 Ohm to ground on the left and 100KOhm on the right. It is normal that one side of the resistor is connected to ground? And I don't understand if the ACOK is a INPUT or OUTPUT for the ISL chip.
                                    • giulio93
                                      • Aug 2021
                                      • 258
                                      • Italy
                                      #38
                                      Can you help me?
                                      • giulio93
                                        • Aug 2021
                                        • 258
                                        • Italy
                                        #39
                                        Please Mon2 can you reply to my answer to your question about the ACOK ad the mosfet you was asking for?
                                        • giulio93
                                          • Aug 2021
                                          • 258
                                          • Italy
                                          #40
                                          Guys?
                                            HP OMEN OMEN by Desktop PC - 870-240na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 03:44 PM
                                            HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            HP OMEN OMEN X by 900-189na OMEN i7-7700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN X by 900-189na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN X by 900-189na boardview and OMEN OMEN X by 900-189na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
