Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
  • wrobbie
    • Jun 2019
    • 5
    • Singapore
    My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according to my FNB58. Relevant section from the schematics:
    I've replaced the IC several times already, initially with 4 aliexpress parts which were all bad/wrong/reused. I bought 7 of them from a trustworthy local supplier and these hold up for several months. The problem always reoccurs though, and I'm sick of replacing that chip every 3-6 months.. At first I blamed my docking station for the failure, but when I stopped using that the next chip died just the same.
    Has anyone seen this sort of issue before? I couldn't find if this is a common issue using google, and I have little experience with repairing USBC laptops. I'm at the point of just jumpering out this protection IC, since it's always plugged in anyway. I can't imagine it's dying because of voltage spikes from my power brick. The next device in the chain is the PD controller, which I have replaced a year ago as well (it wasn't the problem though).
    Cheers,
    Rob
  • trepachka
    • Oct 2022
    • 429
    When you say "it will continuosly reset pd negotiations with the power brick", are you still getting 20V at the USB-C port or does it stay at around 5V?
    • wrobbie
      • Jun 2019
      • 5
      • Singapore
      It will swing back to 5V, then renegotiate 20V, then repeat the loop forever..
      • trepachka
        • Oct 2022
        • 429
        I would think having a failed OVP would result in 5v at USB-C port. Is it possible that the chip you installed is of poor quality with varying threshold? Hence, you get this forever loop with threshold constantly going over tolerances?
        • trepachka
          • Oct 2022
          • 429
          Hey, I just came across a T14 Gen 2 with a similar issue. Initially, it came due to a failed PU1801 chip. After replacing the chip, computer works fine off the dock USB-C port. When plugged into the charging USB-C port, as soon as voltage switches from 5V to 20V, the whole thing resets and repeats. I am going to follow your suggestion and jump the the OVP switch to see if indeed it is causing this issue.
          • trepachka
            • Oct 2022
            • 429
            Jumping the OVP switch did nothing. However, I replaced the TPS chip and the computer is working now.
            • rilley
              MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
              by rilley
              I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
              I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
              My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
              And the resistor L4004 is literally burned.
              From what I see from the schematics, it does not affect any other rails, only the connection to the display...
              07-10-2024, 01:57 AM
            • drscoot
              usbc connector replacement on mobile
              by drscoot
              I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
              The battery is still charging (red led), but no power on.
              I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
              07-13-2025, 02:37 PM
            • Scenic
              Thinkpad T14 Gen1 (Intel ; NM-C931) fan not working
              by Scenic
              Got a weird issue with a Thinkpad T14 Gen1 motherboard out of/currently still in a scrap machine (cracked display, damaged case, otherwise working) that I bought to rob parts from for another thinkpad.
              The motherboard generally works (booted into a test install of Win10 with no issues), however the fan never spins during use. It does spin for about 2 seconds right after turning on the laptop, but after that, never again.
              Just to double-check, I've tried a different (known working) fan from a T14 Gen2 and it does the exact same thing when plugged into this mobo, and the fan from...
              06-29-2025, 04:02 PM
            • nikolayu
              Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
              by nikolayu
              I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
              When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
              Other usbc is charging fine,
              I installed lates bios and firmwares for thunderbolt and battery.
              Could be faulty JHL8040R controller?
              08-31-2024, 11:08 AM
            • sabriTech07
              Acer B3-A30 Firmware - RV02RC07 WW GEN1 (Android 6)
              by sabriTech07
              I'm looking for the official stock firmware for the Acer Iconia One 10 B3-A30 tablet with the following version:
              • Firmware version: RV02RC07
              • Region: WW GEN1 (WorldWide)
              • Chipset: MediaTek MT8163
              • Android version: 6.0
              I've searched various sites but couldn't find this exact version. If anyone has a working download link or can share the firmware, I'd really appreciate it.
              Thank you in advance!
              05-15-2025, 05:52 AM
