i2ite ec read/write using ft232h
  • ndarjo21
    • Nov 2021
    • 81
    • Indonesia
    hi all, i have i2ite written in python by c0d3z3r0. it using for read/write ITE SIO/EC chip via SMBUS. for now, i havent try it because i couldnt buy ft232h in my country. supported device to do this is(based on pyftdi):
    FT2232C/D, FT232H, FT2232H, FT4232H, FT4232HA.
    i attached the link to the i2ite c0d3z3r0 give to me. anyone here have that device above and can test it for me?
    hi codezero, do you plan to improve this code to read and write entire EC firmware, which is usually 128kb?
  • GuidoCr
    • Sep 2025
    • Italia
    Hi, I have succesfully read and write my IT8227E-256 with this mod without errors.
    In my case, it has worked with B interface only, so you must connect the wires correctly...
    • ndarjo21
      • Nov 2021
      • 81
      • Indonesia
      Thanks you so much mate. my programmer also already in my country but haven't arrive yet, i ordered it via my friend when he is in Australia. my programmer is cjmcu ft232h, what is your programmer? can you explain more about B interface? and how it wired correctly? with a picture i hope. or illustration.
      btw, Codezero also made a code to dump flash region of ENE KB9022(i guess it will work with KB9012 too) using this device, but couldnt write the flash region. he suggest me to use flashrom instead. he has it in EDITOOL Github.
      • GuidoCr
        • Sep 2025
        • Italia
        Hi, I have the TIAO USB Multi-Protocol Adapter (TUMPA) v.1 with FT2232H chip.
        The FT232h and FT2232H are different chip, the 232H is single channel while 2232h is double channel, probably it will work but I'm not sure...
        Wiring on the first channel, on the JTAG connector of TIAO, has not worked, iteflash not see the EC, instead wiring on the second channel, on the SPI2 connector, iteflash has immediately found the EC and I'm able to read and write without errors. In your case, you have only one channel, so you dont have to experiment with different channels
        • ndarjo21
          • Nov 2021
          • 81
          • Indonesia
          thank you so much, i hope it will work flawlessly with ft232h. and i hope more people to try the code in another ITE ec
