Dell D520 Boot Hung
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    Dell D520 Boot Hung
    Hello Friends I greet you all hope everyone is doing great, Please I need your help badly I have this Dell latitude D520 which can On but hung when the dell logo is displayed. Kindly help me Thank You.
  • sasser
    • Dec 2012
    • 365
    • Malaysia
    Re: Dell D520 Boot Hung
    Your hdd is confirm ok? Try replace another hdd
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      I Have the hole board in my hand and I try it with external Screen but still
      • SteveNielsen
        Retired Tech
        • 2327
        You're going to have to supply more information than that in order for anyone to be able to help you. You can start by answering Sasser's questions, have you confirmed the hard drive is ok? Have you tried another hard drive or booting from another device?
        • lefos
          • Nov 2013
          • 321
          • Greece
          Try to remove the CMOS battery in order to clear bios settings.
          Check the voltage of the battery also.
          • borbooroski
            • Mar 2014
            • 177
            • Ghana
            Yes I Have removed everything is only the board in hand but still
            And the Power is ok
            • SteveNielsen
              Retired Tech
              • 2327
              Have you tried re-seating the processor? How about the RAM?
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • mpower1226
                Dell optiplex 7090 boot problem
                by mpower1226
                Hi masters, need your help in solving this mystery.
                i have a dell optiplex 7090 micro that i bought from local kijiji.
                when i turn it on, error comes out saying no hard disk.
                i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                it seems as if the computer doesnt recognize the ssd...
                01-22-2024, 10:37 PM
              • mamado mosa
                Slow boot dell latitude 5410 laptop issues
                by mamado mosa
                So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                The problem is it takes more than a minute to boot ..
                The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                Can someone suggest something to fix
                06-19-2025, 06:55 AM
              • estabilito
                Swapped CPU from Fujitsu to Dell - boot guard?
                by estabilito
                Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
                05-27-2025, 05:26 PM
              • Raven7032
                Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
                by Raven7032
                Hello everyone!
                Stucked with this problem.
                Model: Dell G15 Ryzen Edition
                Board: GDL LA-K454P
                Symptoms:
                • Board powers on (consumption ~0.5A), but no boot or display.
                • Fans spin briefly, keyboard backlight turns on, then fans stop.
                • Can be shut down via power button (EC active).
                • No POST, no BIOS splash, no backlight.
                • Led is blinking 2 orange 1 white
                • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
                • No APU_PCIE_RST# - 0V
                Measurements:
                • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
                • EC_RSMRST#
                06-26-2025, 11:47 PM
