Hello Friends I greet you all hope everyone is doing great, Please I need your help badly I have this Dell latitude D520 which can On but hung when the dell logo is displayed. Kindly help me Thank You.
Dell D520 Boot Hung
Tags: None
Re: Dell D520 Boot Hung
I Have the hole board in my hand and I try it with external Screen but stillComment
You're going to have to supply more information than that in order for anyone to be able to help you. You can start by answering Sasser's questions, have you confirmed the hard drive is ok? Have you tried another hard drive or booting from another device?Comment
Yes I Have removed everything is only the board in hand but still
And the Power is okComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mpower1226Hi masters, need your help in solving this mystery.
i have a dell optiplex 7090 micro that i bought from local kijiji.
when i turn it on, error comes out saying no hard disk.
i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
it seems as if the computer doesnt recognize the ssd...-
Channel: BIOS Requests ONLY!
by mamado mosaSo i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
The problem is it takes more than a minute to boot ..
The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
Can someone suggest something to fix -
by estabilitoHello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
by Raven7032Hello everyone!
Stucked with this problem.
Model: Dell G15 Ryzen Edition
Board: GDL LA-K454P
Symptoms:- Board powers on (consumption ~0.5A), but no boot or display.
- Fans spin briefly, keyboard backlight turns on, then fans stop.
- Can be shut down via power button (EC active).
- No POST, no BIOS splash, no backlight.
- Led is blinking 2 orange 1 white
- No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
- No APU_PCIE_RST# - 0V
- All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
- EC_RSMRST#
- Loading...
