Toshiba Satellite C640 No Power Need Help
  • tiubxray
    Rookie
    • Jun 2014
    • 20
    • Malaysia
    Hello to all badcaps forums.
    I am working on this laptop friend of mine, Toshiba Satellite C640 PSC2SL-017006.
    Its been more than a week now to figure out what wrong with this laptop. Plug in the power adapter (voltage tested -pass) but no light from the power led. I disassemble it and I found out that a small chip get really hot (I attached pics).
    The thing is, my friend use his laptop on the bed causing the ventilation blocked. And now the cost to repair it, it's like to buy a new laptop.
    So any suggestions from the "MASTERS a.k.a SIFOO" of badcaps forum.
    Sorry for my bad English. Thanks in advance.
    May the CURRENT be with you!!!!
  • dj_ricoh
    • 2073
    Re: Toshiba Satellite C640 No Power Need Help
    that 51123 its actually TPS51123 a Step-Down Controller that provides the VREG output.
    you can see a DOT on the chip.
    start anti-clockwise and measure the value with adapter on.
    BEWARE! of the probes. Slow and don`t move the probes
    • tiubxray
      Rookie
      • Jun 2014
      • 20
      • Malaysia
      Thanks so much for the reply. Gonna do that after finish work. Thanks again.
      One more thing, does it safe if the chip is getting hot?
      • tiubxray
        Rookie
        • Jun 2014
        • 20
        • Malaysia
        One more question, is it possible to replace the chip, or does the chip is ok and the culprit is other caps?
        I'm a noob, I confess first. Any guides is appreciated.
        Thanks.
        • tiubxray
          Rookie
          • Jun 2014
          • 20
          • Malaysia
          Does this have to with anything?...
          https://cdn.badcaps-static.com/pdfs/...294292b2b0.pdf
          http://www.ti.com/product/tps51123
          • dj_ricoh
            • 2073
            that's the one!
            find the V for each pin
            • tiubxray
              Rookie
              • Jun 2014
              • 20
              • Malaysia
              that's the one!
              OK BOSS!!!
              My multimeter probe quite thick. Is it dangerous if I accidentally short between the pins?
              • lorins_core
                BlackSmith
                • Dec 2012
                • 551
                • Philippines
                I have Encounter before. check the caps around at Ic. may be Have Little Short or Leak...
                • tiubxray
                  Rookie
                  • Jun 2014
                  • 20
                  • Malaysia
                  Thanks. If you have some pics it will help me a lot. Thanks again for the advice.
                  • tiubxray
                    Rookie
                    • Jun 2014
                    • 20
                    • Malaysia
                    This guy do the tps51123 replacement seems so easy!!!!
                    https://www.youtube.com/watch?v=kRbB4ufRpN8
                    • dj_ricoh
                      • 2073
                      I film one to but i did not manage to edit and upload it.
                      Its easy. Last one it took me 5 min and 15 to assamble the notebook back.
                      • alihomee
                        • Dec 2012
                        • 1576
                        • malaysia
                        check for any short around that ic if doest found any short then replace it with same part num
                        • trebo
                          • 514
                          • Wales, UK
                          can you tell us what temperature you set your station to remove and replace that chip
                          thanks in advance
                          • tiubxray
                            Rookie
                            • Jun 2014
                            • 20
                            • Malaysia
                            Will do that, bought a new multimeter. My last one busted.
                            • tiubxray
                              Rookie
                              • Jun 2014
                              • 20
                              • Malaysia
                              that's the one!
                              Pending reading...
                              • tiubxray
                                Rookie
                                • Jun 2014
                                • 20
                                • Malaysia
                                OK, here's the reading from pin 1 to pin 24 counter clockwise starting from the mark.
                                Pin1 (TRIP1) - 0 V
                                Pin2 (VFB1) - 0 V
                                Pin3 (VREF) - 1.99 V
                                Pin4 (TONSEL) - 3.32 V
                                Pin5 (VFB2) - 0 V
                                Pin6 (TRIP2) - 0 V
                                Pin7 (VO2) - 0 V
                                Pin8 (VREG3) - 3.32 V
                                Pin9 (VBST2) - 1.38 V
                                Pin10 (DRVH2) - 0 V
                                Pin11 (LL2) - 0 V
                                Pin12 (DRVL2) - 0 V
                                Pin13 (EN0) - 1.76 V
                                Pin14 (SKIPSEL) - 0 V
                                Pin15 (GND) - 0 V
                                Pin16 (VIN) - 19.38 V
                                Pin17 (VREG5) - 1.67 V
                                Pin18 (ENC) - 0 V
                                Pin19 (DRVL1) - 0 V
                                Pin20 (LL1) - 0 V
                                Pin21 (DRVH1) - 0 V
                                Pin22 (VBST1) - 1.44 V
                                Pin23 (PGOOD) - 0 V
                                Pin24 (VO1) - 0 V
                                So, any defects on the VReg?
                                • dj_ricoh
                                  • 2073
                                  vreg3 stand for 3.3v output. yes?
                                  your first its ok vreg3 3.32 but
                                  vreg5 needs tot be 5v not 1.67v
                                  • dj_ricoh
                                    • 2073
                                    find other chip like this maybe you can find the charging chip!
                                    isl maxim? whe need to find if that's ok!
                                    do you have another way to charge your battery?
                                    that will help a lot. to see if it powers up on battery.
                                    oohh and my latest discovery unplug the bios battery discharge the board and plug the adapter. see if something happens
                                    • dj_ricoh
                                      • 2073
                                      If someone got a schematic for this board please attach it here.
                                      so dam hard to find
                                      • tiubxray
                                        Rookie
                                        • Jun 2014
                                        • 20
                                        • Malaysia
                                        It is like my multimeter display it. I do this check 5 times to make sure there is no mistake.
                                        Done that already, nothing happen. Just the chip is getting hotter if I plug in the adapter.
                                        Thanks for your help. I really appreciate it.
