MS-14C4 unusual chip
  • kalemaroni
    • Jun 2016
    • 176
    This laptop was brought in with no power and had been worked on in another country and they hadn't been successful. The battery and CMOS chip was disconnected.
    I plugged it in and checked the thermal camera and one chip (TPS62134CRGTR) was glowing near the battery connector. I removed the chip only to find that it looked like it never belonged there in the first place. Is there something I'm missing here or has the previous shop replaced a completely different chip?
  • Dcortest
    • Oct 2023
    • 33
    • España
    looks like they replace it with a different chip.... maybe it's a 3v-5V buck converter like TPS1225 or equivalent
    • noname2024
      • Aug 2024
      • 203
      • CỎ MỸ XỊN
      try PU25
      IC PWM,TI/TPS51285BRUKR,WQFN-20pin,DUAL SYNCHRONOUS STEP-DOWN CONTROLLER,HALOGEN FREE
      • kalemaroni
        • Jun 2016
        • 176
        Thank you both, I'll give that a go.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Before soldering a new tps1285, measure resistance to GND on 3V LDO and 5V LDO pin so as not to fry the new chip.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • Troystain
            Help EZP2023+ updated chip database for w25q256jveq?
            by Troystain
            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
            I need to add w25q256jveq chip but I do not know what data should I type.
            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
            11-25-2024, 12:53 AM
          • inck243
            Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
            by inck243
            Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
            The BIOS...
            07-25-2024, 09:17 AM
