lenovo G450 no back light on led screen.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hi guys anyone can help me pls.
    i got got lenovo g450 and it is working but no backlight on the screen.
    1. i have try another screen but it just the same.
    2. i also try to trace cut wires of lcd cable going to the MB. continuity test ok.
    3. and i also did test voltage on lcd connector 40pin. i got 20v on pin 28, 29, 30
    3.3v on pin 2,3,4.
    and i don't no what to do next..
    hope u help me guys god bless all.
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    Re: lenovo G450 no back light on led screen.
    Ram and try to replace processor
      • 30979
      check pin36
      it's the signal to turn the led's on.
      • rickybucalan
        • May 2013
        • 322
        • philippines
        Originally posted by stj
        check pin36
        i check with continuity test CN1 pin 36 to JLVDS1 pin 13 its ok. how do i check if it switching on?
        • dj_ricoh
          • 2073
          • uk
          ok this is simple!
          on 24 what connector do you have? 1 or 2?
          take a snapshot of the connector and write there every voltage you got on the connector!
          with LCD connected ok?
          BEWARE! slow and don`t slip the probes.
          after we will focus on page 36; just locate it KBC U46
          • alihomee
            • Dec 2012
            • 1574
            • malaysia
            there r 3 tyeps of voltages to turn leds on.20v as main voltages 3v for display and 3 v for on off try to short pin 5 and 6 of ur led panal from right side
            • rickybucalan
              • May 2013
              • 322
              • philippines
              Originally posted by dj_ricoh
              ok this is simple!
              connector JLVDS1.
              here is my voltage reading.
              pin pin
              1. 20v 2. 3.3v
              3. 20v 4. 3.2v
              5. 0v 6. 3.2v
              7. 3.3v 8. 0v
              9. 0v 10. 3.3v
              11. 0v 12. 0v
              13. 3.1v 14. 0v
              15. 0v 16. 1.1v
              17. 0v 18. 1.2v
              19. 0v 20. 1.3v
              21. 0v 22. 1v
              23. 0v 24. 1.3v
              25. 0v 26. 1v
              27. 3.3v 28. 1.2v
              29. 3.3v 30. 1.1v
              • dspok
                • Jan 2014
                • 553
                • Nepal
                @rickybucalan
                LED voltage is present in LVDS connector.
                Check LED fuse in TCON board, sometime it blows up which cause no backlight.
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Problem with SIO. You need to supply 3.3v to pin 9 of lvds connector. Check resistance to ground of that pin. Hopefully problem is C852
                  • rickybucalan
                    • May 2013
                    • 322
                    • philippines
                    Originally posted by dspok
                    @rickybucalan
                    i guess its fine. and i already check with another led panel.
                    • rickybucalan
                      • May 2013
                      • 322
                      • philippines
                      i have try your instruction its doesn't work.
                      • lezsimply
                        The Wanderer
                        • 645
                        • Philippines
                        check voltage on pin no.105 of SIO page 36. post result
                        • rickybucalan
                          • May 2013
                          • 322
                          • philippines
                          when i trying to put an external lcd on it doesn't show anything. but when disconnected led cable from mobo its working with external monitor.
                          • rickybucalan
                            • May 2013
                            • 322
                            • philippines
                            its 3.3v lezsimply...
                            • rickybucalan
                              • May 2013
                              • 322
                              • philippines
                              • rickybucalan
                                • May 2013
                                • 322
                                • philippines
                                any body could help me.pls.
                                • lezsimply
                                  The Wanderer
                                  • 645
                                  • Philippines
                                  have you tried different lvds cable?
                                  • dj_ricoh
                                    • 2073
                                    • uk
                                    ok!
                                    lets do this!
                                    I`ll help you!
                                    U46 KBC : no voltage on lvds connector on pin INVT_PWM and DAC_BRIG
                                    check on KBC on pin 21 and 68
                                    • dj_ricoh
                                      • 2073
                                      • uk
                                      DAC_BRIG needs to be ... I think around 3.1(2)v-3.3v its the adjust voltage. no voltage here no backlight. if you connect 3.3v direct you wont have adjust only full brightness.
                                      and INVT_PWM like the name say Invertor power
                                      • rickybucalan
                                        • May 2013
                                        • 322
                                        • philippines
                                        tnx for reply. hmmp i got 3.3v on pin 21 of u46 and 0v on pin 68.
                                        is the 3.3v on pin 21 will appear on pin 11 of JLVDS1?
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • BlueNitesFire
                                          I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                                          by BlueNitesFire
                                          So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                                          03-08-2025, 03:49 PM
                                        • Noursa
                                          Lenovo Yoga C940-15IRH No primary Screen
                                          by Noursa
                                          Hello
                                          I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
                                          the screen seams to be hard to unbuild properly so i want to test it by other way
                                          how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
                                          did u got...
                                          05-04-2024, 10:00 AM
                                        • BMCappelletti
                                          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                                          by BMCappelletti
                                          Hi everyone.
                                          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                                          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                                          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                                          02-18-2025, 12:22 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
