I also had corrosion/oxidation on the power supply part of the RAM, but it is cleaned, and no more worries.
The problem I have now is that the PC works without any problems on the mains, but when I unplug the charger, the screen goes black and I have the keyboard backlight flashing, Caps Lock LED that stays on.
I just have to reconnect the charger, so that the PC restarts and works again without problems.
I have already exchanged the battery with the seller, always a new and original Dell battery.
The worst thing is that the PC charges very well and is able to work on battery.
I just have to do a CMOS clear, and the PC works without problems on battery.
But, I do not change any BIOS settings, I put the PC on battery, after the CMOS clear, I turn it off, black screen and keyboard backlight flashing.
I force stop it with the button, I turn it back on, on battery, same problem: black screen, keyboard backlight flashing and Caps Lock LED lit steadily.
I put the charger, the PC works without any problems.
The BIOS is in version 1.32.
I tried to reinstall Windows, same problem.
The problem also occurs when the PC is in the BIOS.
I do all the DELL tests, no problems.
The BIOS sees the original Dell 240W charger and the battery, charged to 100% and in excellent health.
I tried to modify different BIOS settings but nothing works.
I tried to downgrade to 1.31 (I can't go back further for security reasons, DELL limits), but the same.
I do electronic repairs/microsoldering on laptop motherboards, but in this case, it's not just a problem with a MOSFET/HS charging chip because the PC charges and can still run on battery, just after a CMOS clear.
I really don't see where the problem could come from.
I have already tested 4 BIOS from Electronic Repair School: new BIOS, clean ME, NVRAM, as well as 2 BIOS from Badcaps.
Only the second one from Badcaps allows you to start the PC, all the others are black screen, but I always have the same battery problem.
The BIOS have 5 white LEDs and 3 orange in the worst case and black screen.
Now even with a clear CMOS I can no longer start on battery.
Thanks in advance.
Thanks in advance.
