AN515-54
  • mohamed zahir
    • Jan 2025
    • 15
    • Ajman
    AN515-54
    Please me me diagnose my laptop acer nitro 5 I have multimeter and 0 knowledge so please try to be very precise this motherboard numbers REV 1A EH5VF there is some voltage but very low in mv but maybe I am testing wring
  • mohamed zahir
    • Jan 2025
    • 15
    • Ajman
    This where I am right now
    • mon2
      • Dec 2019
      • 14009
      See attached. Carefully lift up the white sticker and share the full part number on the board. This will be the LA-Hxxxx silk screened markings. We need to confirm this detail.
      What is the history of this unit? Any liquid damage? Just stopped working one day?
      • mohamed zahir
        • Jan 2025
        • 15
        • Ajman
        https://youtu.be/ha04VVPChjQ?feature=shared same exact this one check if something burnt. No liquid damage but heavy usage maybe something got burnt. One day is just stopped working
        • mon2
          • Dec 2019
          • 14009
          Configure your meter to DC mode but at 20V or higher. We need to check if the external power adapter is OK or not.
          Locate the power connector on the board. Mate the adapter to the logic board.
          Carefully check for the adapter voltage. Black meter lead to ground - metal shield is ok on the board. Red meter lead to the power connector. Share pics of the board if not sure but there will be a few inductors / coils nearby the same DCin power connector. We are only confirming if the circuit board is able to receive the ~19v from the power adapter. If not, the power adapter is a suspect and should be replaced with another for testing.
          • mohamed zahir
            • Jan 2025
            • 15
            • Ajman
            The red probe where do I connect can you place arrow
            • mon2
              • Dec 2019
              • 14009
              See attached.
              • mohamed zahir
                • Jan 2025
                • 15
                • Ajman
                I got a reading of 0.20 max but voltage seems to be decreasing each time I test it
                • alfredposadas09
                  • Aug 2020
                  • 343
                  • Philippines
                  do you have 20v on the charger?
                  • mon2
                    • Dec 2019
                    • 14009
                    Use the 20V setting on your meter - see attached. Then attempt to measure again. If this voltage is not a stable ~19v then the power adapter is defective and the logic board should be tested with another. You can use almost any laptop power adapter here for testing. The voltage is very common to other laptop chargers.
                    • mohamed zahir
                      • Jan 2025
                      • 15
                      • Ajman
                      The adapter output is 19v. I tested with the multimeter on 20v it showed 0.26 at the start and gradually decrease to 0 i will try to get a new adapter to check if problem with adapter or board
                      • mon2
                        • Dec 2019
                        • 14009
                        If possible, take a picture of the meter in this setting while you see the 0.26 measurement. The voltage does not sound correct and should be ~19.xxx or ~18.xxx. From the shared details, it appears that you have a voltage under 1 volt where 0.26 = 260 mV. This is very low and confirms the adapter is defective.
                        Test with a known good adapter to continue. Post your updates here. The fault may be only that the power adapter is defective.
                        • mohamed zahir
                          • Jan 2025
                          • 15
                          • Ajman
                          Showing 0.33 I will try to get new adapter
                          • mon2
                            • Dec 2019
                            • 14009
                            Yes, agreed. On the 20v scale, this measurement is showing 0v33 or about 1/3rd of a volt. Certainly not enough to power even a LED let alone the logic board. It appears that the power adapter is defective.
                            • mohamed zahir
                              • Jan 2025
                              • 15
                              • Ajman
                              Power adapter is working fine. Went to a shop and tried a different 19v adapter same voltage 1.7 and gradually decreasing. Seems there is a shortage in the board
                              • mon2
                                • Dec 2019
                                • 14009
                                Remove all power. Disconnect this adapter and also the battery (if it is connected).
                                Configure the meter into resistance mode (use the 2k ohms scale for now). See attached.
                                Test the resistance to ground of the same pins as before. We are testing if there is a short on the DCin power path.
                                What is the resistance measurement?
                                • mohamed zahir
                                  • Jan 2025
                                  • 15
                                  • Ajman
                                  All 3 pins give 0.532 on the 2kohms scale
                                  • mon2
                                    • Dec 2019
                                    • 14009
                                    This is a low resistance to ground at this part of the logic board.
                                    0.532 on the 2kohms scale means the resistance is @ 532 ohms = 532R. While this is not a hard short like 0 ohms or similar, the resistance is of concern.
                                    The next stage of testing will be of the DCin mosfets @ PQB11 and PQB12.
                                    Configure the meter to a higher resistance scale of 2Mohms (highest on your meter).
                                    Then measure the resistance across the PQB11 mosfet:
                                    source (1-2-3) & drain (5-6-7-8)
                                    source (1-2-3) & gate (4)
                                    gate (4) & drain (5-6-7-8)
                                    You can pick any pin from the group of pins (1-2-3) - pick any pin.
                                    We are checking if there is a low resistance. A good mosfet will have hundreds of k ohms of resistance or higher. If the resistance is lower, the part is likely to be defective. Then you will need special tools to remove and replace the part. Suggest to work with a local cell phone tech who is comfortable with board level repairs.
                                    • mohamed zahir
                                      • Jan 2025
                                      • 15
                                      • Ajman
                                      Spent maybe 30 mins trying to find either one. Can you help me find it.
                                      • mon2
                                        • Dec 2019
                                        • 14009
                                        Locate the chip with 'PUB1' in the white silk screen. This square chip is near the battery connector which you have disconnected. This is the charger IC. Next, check on the opposite side of this area to confirm if the mosfets are perhaps soldered on the bottom side of this same region.
                                        • corrize
                                          How to diagnose little step down and power management BGA chips never shorted
                                          by corrize
                                          I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
                                          Sometime, I know only after replacing chips.
                                          Do you have tips for diagnose please ?
                                          05-02-2024, 08:30 AM
                                        • fgreco0124
                                          Microsoft surface pro 7, intel precise touch device error 10
                                          by fgreco0124
                                          I have 50 surface pro 7's. This is for my company that I am in charge of fixing. So many units are not working, meaning the touch isn't with new screen. I get the error precise touch device error 10 in device manager. I flash bios, tried updated drivers but to no avail...Is this a bios issue?
                                          03-21-2025, 09:38 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • someonenotyou
                                          Lenovo ThinkBook G2 ARE- how to diagnose on/off
                                          by someonenotyou
                                          Hi.
                                          I have a laptop Lenovo ThinkBook G2 ARE, which is switching on and after 3 seconds off (Esc, Caps Lock and Num Lock key lights on)?
                                          After leaving it to sit for few days, it would work for 1 hour, then it would switch off.
                                          When switched on again, it would get to Windows boot screen and switch off.
                                          After 3 times like this, it would just light up Esc, Caps and Num lights on keyboard and switch off after 3 seconds without anything on screen.
                                          I have tried a different BIOS, disable on-board RAM with the script, and reflow the RAM chips. Nothing...
                                          05-10-2025, 07:45 AM
                                        • Prott
                                          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                          by Prott
                                          Hello dear badcappers!
                                          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                          Backstory:
                                          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                          If there is a way to narrow down which memory module is faulty it would make my life much...
                                          06-03-2024, 12:05 PM
