How to diagnose mosfet with lab-supply ?
  • Acnologia
    • 444
    • Poland
    • Life is too short.
    Hello to everyone ,
    So far most of the repairs that i've been doing was novice, i would say. With a lot of help from you gents.
    Now ,i got in my hands a lab-supply. So , i have a laptop in my hands that doesn't turn on , remains dead , but at the same time there is no short circuit in the main line (as i think off).
    I know that i should put 1v-2v to ground (black wire) and red wire to close the circuit to a specific place after the DC-IN port.
    Now the question is, where do you place it most of the time , i mean in which specific place after the power port ? Is any place , the same to make the capacitor or the part to heat up and understand where is the short ? (I have thermo camera from phone) so i can easily find it i believe.
    But i'm not sure where do you place the 'red' wire of the lab-supply ,so it's better to ask rather than blow myself up in my face
  • mon2
    • 16807
    https://youtu.be/wp1dPG9_N1w?si=a27Hg6sm8RHZBvo5
    • Acnologia
      • 444
      • Poland
      Will defently look it up . Thank you!
      • c_corr
        HP EliteBook 830 G7 blown low power mosfet unclear type
        by c_corr
        Trying to repair a HP 830 G7 board where I found the Q7001 a low power mosfet blown probably caused by supplying current to a shorted capacitor from the 5V line -> I plan to locate the shorted cap with the usual lab PSU set to 1V and limted to 2-3 amps and a thermal camera.
        Blown mosfet is shortcircuited and has a hole in its casing so I cannot read its marking properly hence my problem.
        Looking in the only schematic available everywhere on the internet the Q7001 shows as being a PJS6416-AU N-channel mosfet but the schyematoic image shows a P-channel mosfet and also there...
        06-21-2026, 04:33 AM
      • GlenBrim
        1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
        by GlenBrim
        I got this recently as-is. Gigabyte 1070 video card.
        DVI port is removed. I don't know why.
        A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
        I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
        The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
        02-14-2024, 02:08 AM
      • potrebitell
        Lenovo L340 Gaming – input MOSFET overheating / unstable power path
        by potrebitell
        Laptop was liquid damaged and cleaned. I removed one shorted capacitor found via injection.
        Issue now:
        • DC jack provides ~20V
        • First input MOSFET drain has 20V, but source drops to ~0V unless lightly pressing the MOSFET area.
          When lightly pressing the input MOSFETs, the laptop starts drawing current and CPU/GPU VRM “squeals”.
        • With slight touch/pressure the laptop actually powers on, starts drawing current, but rapidly begins to overheat heavily the first input MOSFET. As soon as I remove my finger, it immediately shuts off again (it cannot stay on because the MOSFET
        05-20-2026, 09:43 AM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
