[HELP] 820-3437 SEMI DEAD!
  • phantomEVO
    • Mar 2013
    • 488
    i! i don't know the history of ths motherboard...i need help.
    PP3V42_G3H present 3,42v
    i have green light as soon as i connect power supply, that become orange
    diode mode on ppbus_g3h is ok
    pp5v / 3v _s5 present
    I'm pretty sure that smc was changed before trying to fix the problem
    spirom_use_mlb and pm_pwrbtn are 0v also pm_bat_low_l.
    SMC_BATLOW_L still low in bypass mode
    3V3_SUS not present
    AT THE MOMENT, I'M USING BY-3200S ​
  • mon2
    • Dec 2019
    • 14231
    SMC_BATLOW_L should not be low. If low, logic board does not like your power adapter. Test with the official one for this box.
    • phantomEVO
      • Mar 2013
      • 488
      tried with another smc
      tried with original magsafe 2 60w...still the same
      • mon2
        • Dec 2019
        • 14231
        What is the voltage to ground of PPBUS_G3H? Is it stable or cycling?
        Stable or cycling?
        • phantomEVO
          • Mar 2013
          • 488
          stable
          • mon2
            • Dec 2019
            • 14231
            What is the voltage to ground of PPBUS_G3H?​
            • phantomEVO
              • Mar 2013
              • 488
              after changing smc, i have ppbus_g3h at 8,58...SMC_BATLOW_L​ stiill 0v
              • mon2
                • Dec 2019
                • 14231
                If you have a stable ppbus_G3H = 8v58 then the SMC is working since the voltage on ppbus_G3H has been boosted.
                Reference:
                https://logi.wiki/index.php/PPBus_G3H
                In my schematic, there is no SMC_BATLOW_L but there is a PM_BATLOW_L.
                For PM_BATLOW_L, confirm the presence of the pull-up resistor. Confirm the high side voltage of the resistor @ R1410.
                • phantomEVO
                  • Mar 2013
                  • 488
                  thank you8 for your reply! what do you mean with high side
                  • mon2
                    • Dec 2019
                    • 14231
                    Test the voltage on resistor R1410 but the pin that mates with PP3V3_S5. There must be a stable voltage of 3v3 here for this signal to be parked to the logic '1' state. Easier to test both sides of R1410 for a voltage.
                    • phantomEVO
                      • Mar 2013
                      • 488
                      0v on both sides
                      • phantomEVO
                        • Mar 2013
                        • 488
                        i've made a big mistake!!! pp3v3_s5 is not present at all!!! pp3v3_s5 amref smc is present! i've made a big mistake!!! pp3v3_s5 is not present at all!!! pp3v3_s5 amref smc is present!
                        • phantomEVO
                          • Mar 2013
                          • 488
                          By U7501 i have P3V3S5_EN_R- 3.42v; SMC_PM_G2_EN - 3.42v; PP3V3_S5_REG_R- 0v; P3V3_S5_REG_L - 0v; pin24;25;27 on U7501 also 0v
                          • phantomEVO
                            • Mar 2013
                            • 488
                            changed u7501, still the same
                            • phantomEVO
                              • Mar 2013
                              • 488
                              u7501:
                              VREG3: 3.3 volts
                              VREG5: 5 volts
                              VREF: (I'm assuming pin 13) 2v
                              EN S4RS3: 0
                              EN2 3v3S5_EN_R: 3,42 volts
                              SMC_PM_G2_EN 1v
                              • mon2
                                • Dec 2019
                                • 14231
                                What is the voltage to ground on each side of L5001?
                                Remove all power. Measure the resistance to ground of PP3V3_S5_REG_R rail @ L7560. Something is wrong with this rail since the enable for the power rail is OK and this rail should enable.
                                • phantomEVO
                                  • Mar 2013
                                  • 488
                                  3,42 on both sides of l5001
                                  0,35k on l7560
                                  • phantomEVO
                                    • Mar 2013
                                    • 488
                                    SOLVEEEED! it was a broken trace on P3V3_S5_CSN2
                                    • mon2
                                      • Dec 2019
                                      • 14231
                                      0,35k on l7560
                                      350 ohms to ground resistance for L7560 is too low.
                                      reference:
                                      post #6
                                      https://www.badcaps.net/forum/troubl...ssing-pp3v3_s5
                                      Attempt to measure the voltage on this same rail @ L7560 but on immediate power up. Also, is P3V3S5_EN_R always enabled and is stable?
                                      Flowchart suitable for this model:
                                      https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
                                      • mon2
                                        • Dec 2019
                                        • 14231
                                        Just saw your post - excellent!!
                                        So the current loop circuit was broken and this half of the regulator was powering OFF because it felt the voltage was being created but tanked to 0v (due to the missing loop voltage) = assumed the load was too much so power it off.
                                        • phantomEVO
                                          [HELP] Asus x541NC semi-dead!!!
                                          by phantomEVO
                                          hi to all, i dont know the history of this notebook
                                          it has black screen.
                                          i have power led and battery led when i connect the charger.
                                          i've tried an external screen and a different ram module. no luck
                                          fan start spin and nothing else. black screen
                                          i've tried to flash another bios same thing. now when i connect the power supply, it auto power on, but alway with black screen and nothing else
                                          it stays on 0,220a
                                          03-18-2025, 03:30 AM
                                        • moscast
                                          No +VCORE in acer TravelMate TMP2510
                                          by moscast
                                          Hi everyone
                                          I have a problem with this laptop that won't turn on.
                                          The +VCORE is not present and doing some measurements on the ISL95859 I notice this:
                                          VIN present 19.5V
                                          VCC present 5V
                                          VR_ENABLE present 3.3V
                                          PWM_A present 2.5V
                                          FCCM_A not present
                                          PWM1_B present 2.5V
                                          PWM2_B present 2.5V
                                          FCCM_B not present
                                          PWM_C present 0.32V
                                          FCCM_C present 5V
                                          In these conditions should the ISL95859 works and therefore enable the FCCM_A and FCCM_B pins or do I have to check other lines for it to be enabled?
                                          Maybe the...
                                          04-06-2024, 01:49 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
