HP ELITE X2 1013 G3 weird battery issue
  • huzo
    • Sep 2014
    • 178
    • CROATIA
    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager, it doesn't recognize the battery...BUT the battery is showing 0% charge and the laptop is working fine for like 3h playing youtube videos yesterday...so the conclusion is the battery is 0%,laptop doesn't see it, but the laptop works fine on battery! I've tried BIOS update,tried reseting the bios...Nothing was done to the board by the customer,he simply took the old battery out and put the new one ,and now both of them don't work properly...I've tried to put the old battery back and it acts the same as new one...Did the HP put some software on the board that you can't use a second hand battery or what?Like apple used to?
  • mon2
    • Dec 2019
    • 14162
    If the battery is not recognized then the smbus interface on the bms may be defective or one of the smbus lines is stuck.
    Carefully measure the voltage to ground of each pin on the battery pack. Post each measurement.
    • huzo
      • Sep 2014
      • 178
      • CROATIA
      That's the weird thing, it is recognized as the laptop sees the battery is 0% and should be put to charger immediately but the battery works for hours like that..., it's not like it says that it isn't present...Ok i will measure the lines for start later when i'm home...
      • mon2
        • Dec 2019
        • 14162
        Detection of a battery can be through a single line on the battery pack that forces the active low state to the battery charger. The actual charge value of the battery cells is always through the 2 wire SMBUS (I2C) interface used to extract details such as the serial #; battery manufacturer; # of charge cycles, etc.
        • huzo
          • Sep 2014
          • 178
          • CROATIA
          Yeah you are right as always...But what could have happen if the battery was unplugged and another was put in? nothing else happened....i wil try to measure the lines...
          • huzo
            • Sep 2014
            • 178
            • CROATIA
            voltages are :
            GND
            GND
            GND
            GND
            0V
            3.43V
            3.03V
            0V
            BATT+
            BATT+
            BATT+
Name:	Snimka zaslona 2025-01-31 201104.png
            • pc_okay
              • May 2022
              • 241
              • FRANCE
              The curstomer may have use a screwdriver to replace the battery and short data line with BATT+... or he is very unlucky.
              I don't think laptop is charging correctly "drawing around 600mA" depend on you system but laptop may use like 2Amp.
              I have a few experience with broken data line and laptop were still working on battery but no charge and no info on battery.
              • huzo
                • Sep 2014
                • 178
                • CROATIA
                Yes,that is a possibility...there is no schematics for this laptop, or boardview for that matter unfortunately...i changed a random chip near the battery connector, it has sda and clk pins, so i thought data lines go through him, but it' only a temperature sensor manager... G781.TOo bad ,the laptop is still beautifull and usefull...but the battery is working,just not properly...i will wait for mon2 to say is there anything to do to fix it...
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 487
                  • somewhere in europe
                  did you flash the bios/ec?
                  • mon2
                    • Dec 2019
                    • 14162
                    3.43V
                    3.03V
                    These are good measurements. This confirms that the SMBUS (I2C) lines are not shorted and not being shunted to ground.
                    Can you hunt for any silk screening on the logic board that may help us to locate a schematic? Search for 'LA' or 'NM' type of markings.​
                    • huzo
                      • Sep 2014
                      • 178
                      • CROATIA
                      Did an official update yes...something is wrong with communication and i need schematics or board view...
                      • huzo
                        • Sep 2014
                        • 178
                        • CROATIA
                        it's this one exactly...
                        • mon2
                          • Dec 2019
                          • 14162
                          No hits on this board in my database. Hunt for the charger IC that is onboard. Most likely it will be the BQ (Texas Instruments) or ISL (Intersil) series device and will be a square QFN package. Share the full details of what you find. From this detail, we can reverse engineer the board and how it works. If the IC is BQ, the DCin mosfets will be N-channel type.
                          • rediii
                            h???, spurrrn
                            • Mar 2018
                            • 487
                            schematics are unavailable atm. i have had a scenario where the ec rom was broken and that was why the battery wasn't charging right. but first do what mon says... do you have a scope ready?
                            • huzo
                              • Sep 2014
                              • 178
                              • CROATIA
                              IC is intersil 9538h
                              • huzo
                                • Sep 2014
                                • 178
                                • CROATIA
                                i changed it with 9238H, and it acts the same...There is soemthing else going on...
                                • mon2
                                  • Dec 2019
                                  • 14162
                                  Did not know this but are you using the official HP USB-C charger?
                                  Apparently these models demand a 12V PD contract which may not be available on other power delivery bricks. Should not affect the battery detection but interesting to learn.
                                  https://www.reddit.com/r/Hewlett_Pac..._on_even_with/
                                  • huzo
                                    • Sep 2014
                                    • 178
                                    • CROATIA
                                    yes it's original, and i have a Lenovo one also,they act the same... Click image for larger version
ID:	3562372 Click image for larger version
                                    • Sephir0th
                                      • Oct 2020
                                      • 1282
                                      In would neither call those good measurements nor take this as proof that the Battery Clock and Data are fine. Voltages are not close enough to each other.
                                      To finally get something like a clue i strongly suggest to move to the charging controller directly and measure CLK/DAT there. Not only Voltage, but resistance to GND too. Share the result
                                      FairRepair on YouTube
                                      • huzo
                                        • Sep 2014
                                        • 178
                                        • CROATIA
                                        pin 22 and 21 are sda and clk, i have 3.46V on the chip pins,but on battery connector 3.05V on one pin.
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                          APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                                          by sam_sam_sam
                                          This started a few days ago and does this about every 8 hours
                                          After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                                          The battery backup is about 3 or 4 years old
                                          Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                                          06-02-2024, 02:30 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
                                        • danielsak
                                          Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                          by danielsak
                                          Hello, I have issue with Dell Inspiron 3542.
                                          Motherboard marking:
                                          Code:
                                          PWB FX3MC REV: A00
                                          The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                          1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                          1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                          10-11-2024, 04:36 PM
