Ethernet slot lights up steady on Acer aspire one
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Good day everyone. Got a problem on this machine Acer aspire one d250-1151. As soon as I plug ac adapter ethernet slot lights up. Both orange and green are lit steady (no blinks). I also notice processor temp is getting high about 89c, 81c when motherboard is outside the case.
    Although there are problems, the unit it running good. Does not freeze or shutdown. I'm just bothered about the temperatures as the plastic is really getting hot.
    I would like to know if the ethernet port's unusual behavior might contribute to the high temp of the processor. Any inputs are appreciated. thanks
    • 31253
    Re: Ethernet slot lights up steady on Acer aspire one
    i presume the fan is running and the pads are o.k.
    if it's the one i think it is, the cpu hardly gets warm, but the chipset cooks!
    is it an atom cpu with a 965 chipset?
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      Sorry I forgot to mention, yes the fan is working. All clean and pads are ok. Still no reply from owner as to what happened to her unit. But I saw some corrosion on leftside of motherboard along vga and lan port. Maybe I'll try to change cpu fan.
        • 31253
        left side is vulnerable to liquid spills on the keyboard.
        i had one that was written off by that.
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          Owner confirmed that laptop got minor spill on left side part.
          I've got schematics. On page 24 atheros ic, which pin is the supply voltage? are there any disadvantages besides not having Lan when I remove its supply? Cannot find datasheet of atheros ic if it has one.
          • dj_ricoh
            • 2073
            i`ll suggest to take the port out !
            and see what happens maybe maybe.
            its easy then taking the lan chip. ofc maybe its not the lan chip that its making this trouble
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              @dj
              I will try your suggestion man. But I'm afraid to take out lan ports, hard to do.
              • dj_ricoh
                • 2073
                Originally posted by lezsimply
                @dj
                that`s really sad!
                its like when i bought the air station and soldering iron i destroy so many ports until i manage to understand how to take them out.
                find now some crappy boards and take all the ports out without melting the plastic.
                if you took out everything then you can take out that LAN port
                take it like a homework
                  • 31253
                  i think the aspire port is just a socket with a seperate pulse-transformer.
                  it's not a combined job.
                    • 31253
                    btw, did you clean the board with IPA and a brush?
                    • lezsimply
                      The Wanderer
                      • 657
                      • Philippines
                      Good day. I have replaced the cpu fan but still laptop is getting hot. I haven't removed the lan port yet, owner does not care about it. I just want to cut the supply voltage to it to isolate if it is the cause of heat.
                      Could someone please help me identify which pin of atheros chip is the voltage in.
                      @ stj
                      I have cleaned spilled part with 90% isoprophyl alcohol.
                      thanks for help
                        • 31253
                        what's the atheros part number?
                        • lezsimply
                          The Wanderer
                          • 657
                          • Philippines
                          Here's whats written on chip Atheros 8132L-AL1E
                            • 31253
                            page26
                            and before you pull it - check the crystal.
                            • lezsimply
                              The Wanderer
                              • 657
                              • Philippines
                              just want to ask what is the attached diagram for?
                                • 31253
                                some laptop.
                                no idea what model
                                • alihomee
                                  • Dec 2012
                                  • 1594
                                  • malaysia
                                  just take out lan chip
                                  • dj_ricoh
                                    • 2073
                                    I think it will not power up!
                                    because ... I think it got wake up on LAN and that must be a always voltage there.
                                    you know?
                                    • lezsimply
                                      The Wanderer
                                      • 657
                                      • Philippines
                                      what do you guys suggest me to do? I really can't think straight because I've got a lot of work to do.
                                      1. remove port
                                      2. remove lan chip
                                      3. or cut supply voltage to lan chip
                                      I want to rule out video chip for now as this laptop is still working fine.
                                      thanks a lot guys!
                                      • dj_ricoh
                                        • 2073
                                        1. remove port
                                        2. remove lan chip
                                        thanks a lot guys!
                                        I will say to remove lan port because you can put it back if he is not the one
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
