Yep...I broke it MOAR after fixing it. a2681 MacBook Air
  • Jamey021
    • Jan 2023
    • 3
    So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
    Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
    Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can see both APL chips pulse and heat up along with the VRAM on the chip. It pulses on then off, then on then off.
    I am sick, but I am wondering if anyone knows if you can short these M2 - M1- M whatever chips by accidently unplugging the LCD connector.
  • mferna14
    MacBook Air A2681 battery problem after Screen Replacement
    by mferna14
    Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
    12-06-2024, 08:10 PM
  • Dylan Jones
    MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
    by Dylan Jones
    I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
    I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
    06-28-2025, 05:07 PM
  • princepal
    MacBook Air A2681 M2 for repair
    by princepal
    today I received MacBook Air A2681 M2 for repair. The MacBook is working have a startup sound and charging sound but no video on the screen I checked the backlight voltage which is 0V then I checked the backlight ic enable there is 0V on anyone please help me.
    04-30-2024, 04:18 AM
  • daltonjr.
    Macbook a2681 u7700 chip
    by daltonjr.
    water damaged MacBook a2681 M2 draws 5v 0,4A, u7700 gets hot, so I guess it must be bad.. Now I wonder, where could I get that chip? there is nothing on aliexpress... is it only good from same doner board?
    Thanks for help!
    02-20-2025, 03:47 AM
  • envym
    MacBook Pro 2018 with Activation Lock
    by envym
    Hi everyone!
    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
    06-27-2025, 08:54 AM
