Macbook a2681 u7700 chip
  • daltonjr.
    • Jul 2016
    • 49
    • Austria
    water damaged MacBook a2681 M2 draws 5v 0,4A, u7700 gets hot, so I guess it must be bad.. Now I wonder, where could I get that chip? there is nothing on aliexpress... is it only good from same doner board?
    Thanks for help!
  • mon2
    • 14621
    What are the topside markings on u7700? Post a clear pic.
    • daltonjr.
      • Jul 2016
      • 49
      • Austria
      That was stupid of me.. it's APL109D, have found it now, thanks mate!
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • Loki_Fido
        Requesting help identifying chip in Macbook Pro A2485
        by Loki_Fido
        Hi ya folks,
        I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
        It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
        I replaced it and the SSD are fine. No more shorts.
        But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
        But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
        Chip marking...
        08-07-2025, 10:17 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • mferna14
        MacBook Air A2681 battery problem after Screen Replacement
        by mferna14
        Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
        12-06-2024, 08:10 PM
