Macbook 820-2279-A fan not spinning
  • tony359
    • Oct 2018
    • 264
    I have this old macbook which I am trying to repair for nostalgic reasons
    The fan does not spin until the MB overheats and shuts down.
    The fan gets 5V but there is no PWM on pin 3. The same with the fan unplugged, no PWM on pin 3. The fan shows some glimpse of activity every 5 seconds. Sometimes it spins for half a revolution and that's it.
    From the schematics (obtained from this forum, THANKS!) I see there is a mosfet getting signal from the SMC. The mosfet gets 3.3V but there is no input - well, there is 3.3V. I removed the mosfet to see if I had anything from the SMC but I still have nothing. One thing I noticed is that with the fan connected I see 5V on the PWM pin, coming from the fan. Is the PWM supplied to the fan as a square-wave signal or is the driver pulling to ground the signal coming from the fan?
    I tried powering the fan "manually": I supplied 5V, GND and I plugged the PWM to a signal generator but besides making some noise depending on the frequency I sent, the fan would draw 100mA, show a glimpse of activity and do nothing.
    Before I buy another fan, I am puzzled about that PWM signal not showing on pin 3 even with the fan disconnected.
    Any ideas?
    Thanks!
  • tony359
    • Oct 2018
    • 264
    Just to complete this thread, it was just a faulty fan. A working fan works when supplied with 5V. And it works in the MacBook!
    • zaler808
      Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
      by zaler808
      Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
      05-23-2024, 05:17 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
