Asus A52JE-EX209V no display
  • anno
    • Sep 2007
    • 140
    • netherlands
    i have an Asus A52JE-EX209V laptop, with no display on lcd and external.
    the owner said he flashed the bios and then get black screen so i re-programmed the bios but that didn't help.
    i checked vga connector and i found 3.3v on hsync and vsync, but no other voltages (red , geen, blue etc....)
    checked voltage on coils to cpu and found 0.8v
    i can`t find a schematic of mainboard .it is asus k52jr mainboard.
    is there anything i can check. i was thinking of reflowing gpu
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Re: Asus A52JE-EX209V no display
    Hi mate, What CPU does this Laptop has? Should be Intel i series if it is the 1st generation CPU then try to swap with working one and check for Display.
    New generation Motherboards has switching Graphics so always good to check all easy one first. Good Luck!
    • anno
      • Sep 2007
      • 140
      • netherlands
      hi
      it has Intel Core i3-330M cpu.
      the cpu has intel hd graphics in it and also an ati radeon hd5470 gpu on mainboard.
      what is switching graphics? and can someone explain how the display works?
      i mean when turning on laptop it uses the graphics built in cpu? then when OS is loading and driver is installed it is using the radeon gpu?
      • lefos
        • Nov 2013
        • 321
        • Greece
        Can you tell us the gpu's chipset model number?
        • anno
          • Sep 2007
          • 140
          • netherlands
          do you mean ati radeon hd5470 ?
          • cephei328
            sparky
            • Feb 2014
            • 49
            • NewZealand
            Hi anno,
            Intel i series 1st generation CPU's can fail easily. Try swapping with new or working CPU and check the display before replacing or doing any replacement.
            "Switching graphics : The Intel cpu has inbuilt graphics processor (low end) along with you dedicated GPU (high end) - The system will switch between both graphics according to the requirement to save power"
            • anno
              • Sep 2007
              • 140
              • netherlands
              hi cephei328
              thanks. i will try another cpu of a friend
              • anno
                • Sep 2007
                • 140
                • netherlands
                i tryed my cpu in another i3 laptop and is was working. so my cpu is fine. is there anything else what i can try?
                • khaahk
                  • Dec 2013
                  • 810
                  • Estonia
                  If the owner did not lie, then the problem is in bios. Where did you take the bios from? Upload original dump for comparison.
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    @anno
                    re-programing bios with latest ver may help.
                    • anno
                      • Sep 2007
                      • 140
                      • netherlands
                      i programmed the bios from a file from asus website. should be ok
                      • anno
                        • Sep 2007
                        • 140
                        • netherlands
                        is it possible the bios chip is bad? is there a way to test this? i still not fixed the laptop
                        • Scootie
                          • Feb 2014
                          • 133
                          I dont think u can write a bios chip which is defective.
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            if bios is bad notebook shouldn't start right ?
                            it may be northbridge problem.... but just suppose that as i had a similar configuration (see hp g62 i had ) it has i3 cpu, hd5470 and problem was northbridge.
                            let's wait for other opinion
                            • lefos
                              • Nov 2013
                              • 321
                              • Greece
                              I guess the gpu's chipset is 216-0774007 right?
                              Can you do a slight reflow on it and inform us back your results?
                              I think that the problem is there. Can you also tell us the northbridge's number of the chipset?
                              • sparker1
                                • Sep 2011
                                • 343
                                This isn't the exact board but it might help.
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  if gpu coil is not shorted i think is more northbridge problem.
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1489
                                    • portugal
                                    anyone iwht this schematic ? K52JR ?
