DELL P40G (LA-9591P REV 1.0) no power
  • madjid911
    • Dec 2016
    • 410
    • France
    Hello, I have a laptop DELL P40G (LA-9591P REV 1.0) that does not work, when I press the power button, the start LED sometimes lights up then goes out immediately.
    I checked everything on the motherboard, no short, even the processor has good resistance, no liquid damage.
    So I started to check the S5 voltages, I'm missing it +3.3V_M and +1.05V_M.
    PU300 and U45 are well powered with +5V_ALW but PU300 does not give +1.05V_M (no EN_+V1.05SP neither​), and U45 does not give +3.3V_M, there are no shorts around.
    schematic and bordview : https://www.badcaps.net/forum/docume...ew#post3479536
    Can you help me understand and find where the problem comes from please, I am not an expert
  • madjid911
    • Dec 2016
    • 410
    • France
    SIO_SLP_A# : 0V, the processor is dead?
    • mon2
      • Dec 2019
      • 14657
      Remove all power. Meter in resistance mode. Measure the resistance to ground of the VCORE power rail used to power the CPU. Share the measurement in ohms.
      • madjid911
        • Dec 2016
        • 410
        • France
        +VCC_CORE : 123 ohms
        • mon2
          • Dec 2019
          • 14657
          CPU is not shorted with such a high resistance.
          Remove all power. Meter in resistance mode. Measure the resistance to ground of +3.3V_M. What is the resistance in ohms? U45 loadswitch may be defective.
          • madjid911
            • Dec 2016
            • 410
            • France
            yes I was also surprised to have a processor with such high resistance, it's the first time I've seen that
            +3.3V_M : 0,488 MOHMS
            • mon2
              • Dec 2019
              • 14657
              Check the voltage to ground of pins 5, 6, 7 on U45.
              • madjid911
                • Dec 2016
                • 410
                • France
                PIN 5 : 100KOHMS
                PIN 6-7: 3,2KOMHS
                • madjid911
                  • Dec 2016
                  • 410
                  • France
                  I will order U45
                  • mon2
                    • Dec 2019
                    • 14657
                    You have shared the resistance for the above pins.
                    Check the voltage on these pins (with the power or battery attached) to confirm the voltage is appearing at the input of the load switch AND the load switch is being enabled. Under this condition, the output voltage must be available unless the switch is defective. The output is not shorted so no reason for the voltage to be absent.
                    • madjid911
                      • Dec 2016
                      • 410
                      • France
                      Yes sorry, pin 6-7: 3V3. pin 5: 0V => same with the battery connected
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • master3112
                        by master3112
                        07-29-2025, 01:55 PM
                        Dell Thunderbolt Firmware
                        by SMDFlea
                        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                        The SKU is in brackets (****)
                        EDIT: NVM65...
                        01-26-2025, 06:22 AM
                      • F R 2568
                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                        by F R 2568
                        Hello all,
                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                        If the laptop is only connected to the AC adapter (battery removed):
                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                        The power/battery...
                        01-08-2025, 05:45 AM
