A1932 no image
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    A1932 no image
    I've stupidly connected A1932 screen while the battery is plugged in..
    ALS CAM coil was burnt to ashes.. replaced it and diode mode readings all ok
    U5200 (I2C TCON) chip had little high diode mode readings on the display lcd not T2 side; replaced and it diode mode are better..
    but still no image
    I've taken diode measurements from LVDS connector; all ok now (edited)
    what am I missing?
    no 5v sw no 3v sw
    it booted normally and DFU restore successful
  • mon2
    • Dec 2019
    • 14011
    External video ok? Caps led key toggles? Just to confirm the boot is truly ok.
    • iMuhtaseb
      • Jan 2017
      • 122
      • Palesine
      no external image..
      I mentioned that it boots normally because it showed an image and booted normally one time without issues and then it stopped
      • mon2
        • Dec 2019
        • 14011
        Since you are missing some voltages, what is the voltage to ground of PPBUS_G3H? (check @ F7000)
        What is the voltage and current draw at the power adapter?
        • iMuhtaseb
          • Jan 2017
          • 122
          • Palesine
          It did not give any image.. when I mentioned that it booted normally it happened when? Here is what happened:
          I left it two days ago to do DFU restore and left the office.. next day I came it was on question mark meaning it completed and it was DONE... all OK.. computer was perfect up until I took the board of to clean.. when I returned it to housing; not image.
          I did the same thing yesterday leaving it to do DFU restore and left the office.. same thing happened and now it boots and shows image without issues.. no problem whatsoever.. I'm sure if I take the board out and disconnect the battery the problem will reappear..
          • iMuhtaseb
            • Jan 2017
            • 122
            • Palesine
            never mind.. I should have done a DFU restore after replacing the ALS CAM coil and U5200​ chip because now it's all good..
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • irepair559
              Ps4 1215a hdmi diode readings good everything good but no pic??
              by irepair559
              PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
              01-05-2023, 12:32 AM
            • naderk
              MacBook Air A1932 820-01521-02
              by naderk
              I am trying to repair the laptop mentioned in the title. I have been searching posts looking for readings similar to mine but cannot find any. I am fairly new at this so please be gentle 🏳
              History:
              No water damage, screen cracked. Laptop doesn't draw any amps on USB meter from either USB C port. Removed the board, same no amp draw. No standby light on the board. Apart from dust board looks great! No obvious visible burnt components. At the moment I dont have a Mac charger, its on the way. I am using a samsung USB C charger which should get the board on...
              02-09-2025, 09:03 PM
            • Instafixx
              Macbook A1932 820-01521 No Image
              by Instafixx
              Hi, I have a Macbook 820-01521 A1932 model.
              The machine switches on - as confirmed by plugging in an external adapter but there is no image on the screen. Backlight is ON.
              Doing a PRAM/SMC Reset makes the screen active once in a while for a few seconds but it again goes off. (SMC/PRAM reset doesnt work always.)
              No Corrosion on the board but there was a lot of dust. Cleaned that.
              Anyone faced such an issue before?
              01-11-2023, 05:53 AM
              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-06-2024, 10:56 AM
