Macbook A1932 820-01521 No Image
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hi, I have a Macbook 820-01521 A1932 model.
    The machine switches on - as confirmed by plugging in an external adapter but there is no image on the screen. Backlight is ON.
    Doing a PRAM/SMC Reset makes the screen active once in a while for a few seconds but it again goes off. (SMC/PRAM reset doesnt work always.)
    No Corrosion on the board but there was a lot of dust. Cleaned that.
    Anyone faced such an issue before?
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A1932 820-01521 No Image
    Originally posted by evolpe
    dead cpu
    How is it a dead CPU? It is switching on and working fine. Only there is No Image on the LCD.
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      08-28-2025, 01:09 PM
    • nikolayu
      MacBook Air A1932 internet recovery loop
      by nikolayu
      I have A1932 that is going to internet recovery every time.
      i tried nvram and smc reset but it looks that MacBook is not reacting to that.
      i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
      keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
      also won’t open option to boot from usb device.
      and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
      07-22-2025, 02:55 AM
    • baglaivlad
      MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
      by baglaivlad
      Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
      Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
      01-09-2024, 09:55 PM
    • TOMÁŠ
      MacBook Air A1932
      by TOMÁŠ
      Hi, I've never worked with a MacBook before, so I need some advice.
      I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
      05-20-2025, 11:19 AM
