Macbook A1932 820-01521 No Image
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hi, I have a Macbook 820-01521 A1932 model.
    The machine switches on - as confirmed by plugging in an external adapter but there is no image on the screen. Backlight is ON.
    Doing a PRAM/SMC Reset makes the screen active once in a while for a few seconds but it again goes off. (SMC/PRAM reset doesnt work always.)
    No Corrosion on the board but there was a lot of dust. Cleaned that.
    Anyone faced such an issue before?
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A1932 820-01521 No Image
    Originally posted by evolpe
    dead cpu
    How is it a dead CPU? It is switching on and working fine. Only there is No Image on the LCD.
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • baglaivlad
      MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
      by baglaivlad
      Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
      Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
      01-09-2024, 09:55 PM
    • TOMÁŠ
      MacBook Air A1932
      by TOMÁŠ
      Hi, I've never worked with a MacBook before, so I need some advice.
      I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
      05-20-2025, 11:19 AM
    • Arshad alam4659
      macbook air a1932 sign out of find my
      by Arshad alam4659
      Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
      04-09-2025, 12:37 AM
    • astroboypaul
      Macbook A1932 Some Keys Not Working
      by astroboypaul
      Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
      Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
      06-10-2024, 05:32 AM
