acer 5920g modem missing, changed video card ..still no video
  • awadesh15
    • Jun 2014
    • 17
    • india
    Hai friends I hv acer 5920g with nvidia geforce 8600 chip...86-770-A2 VER 1.3.it got last year rebolled now again failed.no more rebolling helped.so I bought old but working on other laptp nvidia board withvall same configuration except ver is 1.5.I replaced in laptop and te restarts afetr 6 attempt to no vedio at all.i connected extnl display ..tv fn+5/f5 changed ram..dessemble assemble. Hard reset ...but nothing helped...I KNOW MY LAPTOP NEVER SHOWED VIDEO WHEN WAS FULLY FUNCTIONAL. ...MY QUests
    1.I CAME TO KNOW MODEM IS MISSING. .LAST TECH GUYS LOST IT...DO I NEED TO PUT MODEM TO GET VIDEO OUT?
    2.I GOT SECOND HAND NVIDIA CARD WITH DIFFERENT VER THAT IS 1.5....IS IT CAUSING PROBLEM..
    3.I NEVER FLASHED BIOS...I HEAR W7 WELCOME SOUND AND SKYPE ..ALT+F4 CAUSE TO SHUT DOWN. .OK.
    4.IF NEED TO FLASH...I NEED TO DO BLINDLY..PL TELL ME STEP BY STEP PROCEDURE FOR IT...
    THX..WAITING FOR KIND ANSWERS FROM TECH GUYS..ANY HELP WILL BE GREATLY APPRECIATED.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: acer 5920g modem missing, changed video card ..still no video
    hi, first dont use caps lock = shout...bad thing.
    second is the video card taken from another acer laptop? it not u need to program video card bios with one vbios for acer 5920g ... vbios available on tech powerup.
    modem is need to make pc power on everytime... or it will power after 5-6 times.
    edit:
    try to power on the laptop 6 times.... if on the 6th or 7th it stay on then is only a modem problem.
    • awadesh15
      • Jun 2014
      • 17
      • india
      Sorry for caps..I powered on as u said..it just stay on without video output...white screen only...
      I powered on it keeps restarting..just before it loads w7 on 6th attempt I again pressed power button(it understood this was ur instructions)...this was unresponsive by laptop it loaded w7 without vedio out...I heard only w7 sound..
      How can I use vbios if laptop is not showing anything..does it mean I need flash vbios.?any next instructions. ?
      Thanks for your instructions sir...
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        i cant even read this thread. (* ー_ー )!!
        Follow the white rabbit.
        • dj_ricoh
          • 2073
          • uk
          LOL!
          you`ll never know if he becomes the best tech guy ever so... :P
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            blank screen is video card problem: bios, vbios or bad bga.
            for vbios change there is one sure solution: take vbios out, program it then put it back.
            second option is try crisis recovery method for vbios flash. some guy on italian forum report success for that.
            Remove the MXM card from the machine.
            Download WinCris 1.0.0.4.
            Download the patched BIOS, rename it to BIOS.WPH, and put it in the directory of WinCris.
            Use WinCris to create an USB crisis recovery disk. (There is no crisis to recover in this case, but a crisis disk can also be used for regular flasing.)
            Shut down the machine, remove the battery and unplug the AC.
            Plug in the crisis USB disk.
            Press and hold Fn+Esc. Plug in the AC adapter.
            Still holding Fn+Esc, press the Power button. Release Fn+Esc.
            When the laptop shuts down, reinstall the MXM card, and you should be good to go.
            this is for modded 5920g mxm support (to support more vga)
            http://www.fileswap.com/dl/XbVl3J7EUS/
            first try this procedure for more mxm support.
            • awadesh15
              • Jun 2014
              • 17
              • india
              ok i will try soon and let you know results...thx
              • awadesh15
                • Jun 2014
                • 17
                • india
                sorry i am replying late...is there risk of damaging bios permanently by such flashing on motherboard....?can i replace original vbios chip to new one for getting result....is it possible?i want to keep bios flashing last option?
                • dj_ricoh
                  • 2073
                  • uk
                  don`t flash it !
                  you said white screen? does go to external?
                  in order to do a proper test in external disconnect the internal cable screen.
                  if not reflow the mxm card then we talk next.
                  • awadesh15
                    • Jun 2014
                    • 17
                    • india
                    yes screen is white and i do not hear beep sound as i should be after power on ...does it mean motherboard donot recognise video card from another notebook...ok anyway i will reflow/ tell u later
                    • awadesh15
                      • Jun 2014
                      • 17
                      • india
                      ok i will try ur tips disconnecting internal cable before trying ext ..monitor
                      • awadesh15
                        • Jun 2014
                        • 17
                        • india
                        where can i find vbios chio on video card...i do not recognise ..since i can repair mobile..chip changing is easy for me...
                        • dj_ricoh
                          • 2073
                          • uk
                          leave the VGA bios!
                          it has nothing to do with it!
                          if you got no progress after video reflow go to northbridge
                          • awadesh15
                            • Jun 2014
                            • 17
                            • india
                            Thx ..I just disconected internal and connected ext monitot...I got acer logo and then w7 welcome screen ..but then signal always lost to blank. ?.In just hear then after w7nwelcome sound and skype log in...pl what next. Pl remember my laptop has no modem?
                            • awadesh15
                              • Jun 2014
                              • 17
                              • india
                              I follwed u ..I disconnected internal then connecte ext monitor ...MAGIC ..on power on I saw acer log...off course after 6 restart as missing modem. ?.acer logo then w7 welcome screen but then aftersignal is lost always...pl help..
                              • awadesh15
                                • Jun 2014
                                • 17
                                • india
                                I can go to bios set up too...and see cmos system time old .....2007///does cmos battery died ??
                                • trebo
                                  • 514
                                  • Wales, UK
                                  that's a possibility, but more likely to be the battery has been removed at some time or disconnected
                                  check cmos battery voltage if less than 2.6v replace it
                                  if c/batt ok then reset date = time
                                  • awadesh15
                                    • Jun 2014
                                    • 17
                                    • india
                                    i hv reinstalled window 7 successfuly..all works good only on external monitor....should i consider my display dead..inverter ...
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      i reballed a vga, but as i said maybe bad vbios or bad reball and on a working 5920g give white screen.
                                      • dj_ricoh
                                        • 2073
                                        • uk
                                        i saw this 2 weeks ago.
                                        it waS black screen and after reflow it was white
