HP Pavilion Power 15-cb G75A can't work on battery
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    I have an interesting issue with an HP Pavilion Power 15-cb011nc laptop. The laptop works perfectly fine with the AC adapter connected, charges the battery correctly to 100%, but when the power adapter is disconnected in Windows, it shuts down immediately. When trying to power it on using only the battery, it only shows the "HP" logo, and as soon as it starts booting the operating system, it shuts down immediately. However, the voltage on +VIN is stable and holds at approximately 17V, which means the MOSFET controlling the battery power is correctly open and supplying the main power rail.
    The laptop came to me with a damaged DC-in connector; the center pin was broken. However, it was still charging. I have already replaced the DC-in connector.
    The charging circuit uses a BQ738 controller, which appears to be working correctly.
    I performed measurements with an oscilloscope, and when the shutdown occurs, there is no voltage spike on the main power rail; only a very slight drop in battery voltage is visible during the boot attempt. The SDA_CLK and DAT_CLK signals also show the expected behavior.
    This simply doesn't make any sense to me.
    Motherboard: G75A, DAG75AMBAD0, rev D
  • mon2
    • Dec 2019
    • 14657
    Have you tested with another known good battery?
    • sopik78
      • Nov 2013
      • 519
      • Czech Republic
      I don't have another battery available, and I have no way to test it elsewhere. However, it appears to be fine; the voltage is stable, and it charges correctly
      • sopik78
        • Nov 2013
        • 519
        • Czech Republic
        The problem has been resolved. The root cause was identified as a faulty Keyboard Controller (KBC), specifically the IT8987E chip. Following its replacement, the notebook now operates correctly on both AC power and battery power.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • mkdj
          ASUS X571 no power : battery issue?
          by mkdj
          Mark and model: ASUS X571
          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
          Tests already made:
          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
          - I have removed...
          07-14-2025, 09:16 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
          09-14-2023, 11:10 PM
          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
          09-12-2024, 03:44 PM
          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
