HP Pavilion Power 15-cb G75A can't work on battery
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    I have an interesting issue with an HP Pavilion Power 15-cb011nc laptop. The laptop works perfectly fine with the AC adapter connected, charges the battery correctly to 100%, but when the power adapter is disconnected in Windows, it shuts down immediately. When trying to power it on using only the battery, it only shows the "HP" logo, and as soon as it starts booting the operating system, it shuts down immediately. However, the voltage on +VIN is stable and holds at approximately 17V, which means the MOSFET controlling the battery power is correctly open and supplying the main power rail.
    The laptop came to me with a damaged DC-in connector; the center pin was broken. However, it was still charging. I have already replaced the DC-in connector.
    The charging circuit uses a BQ738 controller, which appears to be working correctly.
    I performed measurements with an oscilloscope, and when the shutdown occurs, there is no voltage spike on the main power rail; only a very slight drop in battery voltage is visible during the boot attempt. The SDA_CLK and DAT_CLK signals also show the expected behavior.
    This simply doesn't make any sense to me.
    Motherboard: G75A, DAG75AMBAD0, rev D
  • mon2
    • 14216
    Have you tested with another known good battery?
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      I don't have another battery available, and I have no way to test it elsewhere. However, it appears to be fine; the voltage is stable, and it charges correctly
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        The problem has been resolved. The root cause was identified as a faulty Keyboard Controller (KBC), specifically the IT8987E chip. Following its replacement, the notebook now operates correctly on both AC power and battery power.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          09-14-2023, 11:10 PM
          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 03:44 PM
          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
