Dell Latitude 7410 dead and amber light as long power button is pressed.
  • Andreasbest
    • Aug 2014
    • 1175
    • Hellas ( Greece )
    I will check again the area around bios chip, in case Ii damaged something.
    Meanwhile I suspect that EC is corrupt.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      Originally posted by vidvansh
      I am having the same issue with my laptops. I tried 2 laptops which were bio locked. I de-solder the bios chip on both, flashed them and then soldered them back. After that both the laptop are not turning ON, no activity.Amber light turns On when pressing power button. Can not figure out what could be the issue. On 1 laptop which is dell latitude 5400 i can see that i am missing a resistor near the bios chip. Don't know what to do next. On 2nd laptop which is 7410, i cannot see any missing part. Any guide on what can i try to fix those laptops.
      Post some nice clear photos of the areas you worked on giving a good perspective around the bios chip and we'll try to help. Did you try to reflash the original and see what happens?
      • vidvansh
        • Mar 2025
        • 20
        I flashed the chip with original dump and soldered it on the motherboard. no output. same issue of no activity and amber light when power button pressed.
        I set down bios chip 2-3 times to confirm it is making contact with the board. Is there anything else i need to try.​
        • Andreasbest
          • Aug 2014
          • 1175
          • Hellas ( Greece )
          vidvansh has tried any possible way involving BIOS, like I did.
          Problem is not on BIOS but on the rest motherboard, there is a high chance to have corrupted EC.
          • hopkok
            • Oct 2014
            • 178
            • Slovakia
            Hi, remove heatsink, clean mobo with IPA and post picture of Bios area. How much heat did you use? Any short under wifi module, its close to bios chip.
            • vidvansh
              • Mar 2025
              • 20
              I removed the heat sink and these was a capacitor which got blown away from near to Bios chip, i soldered it back looking at old pictures to confirm where it should be. Now the laptop is booting fine.
              • Andreasbest
                • Aug 2014
                • 1175
                • Hellas ( Greece )
                #27
                Can you please point the blown cap location please?
                • vidvansh
                  • Mar 2025
                  • 20
                  Black color capacitor got blown away from here which was stuck under the heat sink. I soldered it back and it worked.
                  Can anyone help me identify what part it is called so that i can order some as i have one dell latitude 5400 where 1-2 capacitors are blown while removing bios chip and i cannot find them on the motherboard.
                  • Sephir0th
                    • Oct 2020
                    • 1282
                    Compatible schematics was shared with Post #2 on Page 1. It is a 22 Ohms resistor.
                    FairRepair on YouTube
                    • hopkok
                      • Oct 2014
                      • 178
                      • Slovakia
                      #30
                      I was expecting that...
                      • Andreasbest
                        • Aug 2014
                        • 1175
                        • Hellas ( Greece )
                        #31
                        Unfortunately in my case everything looks intact.
                        The resistor is present and 22Ω
                        • davidebeatrici
                          • Dec 2020
                          • 86
                          • Italy
                          #32
                          The CPU happens to be right next to the BIOS chip. Have you checked if they are getting powered?
                            DELL Latitude 7410 Notebook 7000 Specification for Upgrade or Repair
                            This specification for the DELL Latitude 7410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7410 boardview and 7410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7410...
                            09-06-2024, 08:10 PM
