ACER VN7-591G won't turn on
  • DolphiServiceLTD
    • Apr 2024
    • 28
    Hello guys!
    I have a problem with one Acer VN7-591G
    So the first mosfet getting hot. I mark it with blue.
    When i tried to put more than 3.3V, it's getting shorted on the power stantion and the mosfet getting more than 100 degrees.
    I am not so familiar with this laptop and i would like to get some help if someone know where i can search for short ..
    Thank you in advance!
    • 21841
    Post a link to the schematic/boardview
    • DolphiServiceLTD
      • Apr 2024
      • 28
      https://www.badcaps.net/forum/troubl...es_hsb-14206-1
      For Schematic and boardview
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • ipn00tic
        Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
        by ipn00tic
        Hello everybody,
        I'm learning alone at home (with you) of course.
        I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
        The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
        I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
        The VCC_GT power...
        03-01-2024, 05:32 AM
      • jermac0711
        ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
        by jermac0711
        Brand : Acer
        MOBO: PEW71 LA-5894P
        Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
        I hope you guys can shed some light. Thank you so much in advance.
        12-17-2024, 08:25 PM
        09-06-2024, 05:27 AM
      • Kshi
        Acer a515-52g no power 19v not passing through first mosfet
        by Kshi
        I purchased this laptop from fb marketplace
        and the previous tech jumped 1st mosfet. maybe it got fix, then time comes by jumpering fried the charging ic?
        tried to change mosfet but it does nothing 19v is not passing through 1st mosfet
        tried to jumper again, I got 5vlp and 3vlp but 5valw and 3valw is missing
        I suspect that the charging ic is bad? If so how do i test if it is bad.
        Cant see any short or corrosions on board
        schematic and brd view attached below
        07-25-2025, 01:13 AM
