ACER VN7-591G won't turn on
  • DolphiServiceLTD
    • Apr 2024
    • 25
    Hello guys!
    I have a problem with one Acer VN7-591G
    So the first mosfet getting hot. I mark it with blue.
    When i tried to put more than 3.3V, it's getting shorted on the power stantion and the mosfet getting more than 100 degrees.
    I am not so familiar with this laptop and i would like to get some help if someone know where i can search for short ..
    Thank you in advance!
    • 20659
    Post a link to the schematic/boardview
    • DolphiServiceLTD
      • Apr 2024
      • 25
      https://www.badcaps.net/forum/troubl...es_hsb-14206-1
      For Schematic and boardview
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • ipn00tic
        Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
        by ipn00tic
        Hello everybody,
        I'm learning alone at home (with you) of course.
        I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
        The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
        I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
        The VCC_GT power...
        03-01-2024, 05:32 AM
      • jermac0711
        ACER PEW71 LA-5894P CPU_B+ MOSFET NEED HEPL
        by jermac0711
        Brand : Acer
        MOBO: PEW71 LA-5894P
        Issue: initially no power. PQ73 mosfet is busted. (AO4466) . Unit has power now but PQ87 is heating up too much (observerd under thermal camera) causing to shut down the system. I tried to remove the removable CPU and the mosfet temperature went normal. I have a replacement CPU from same model but everytime there's a CPU, mosfet PQ87 temperature is rising rapidly.
        I hope you guys can shed some light. Thank you so much in advance.
        12-17-2024, 08:25 PM
        09-06-2024, 05:27 AM
      • vexarvf1s
        Acer: No power after first MOSFET no short? Looking for guidance.
        by vexarvf1s
        Looking for guidance in tracking down missing main power rail.
        I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
        First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
        So checked for voltage on the gate of the first MOSFET and...
        05-13-2023, 07:55 AM
