Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
  • 1centchips
    • Feb 2016
    • 41
    I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
    The laptop is just out of warranty.
    The laptop continues to freeze randomly with the blinking amber charging light.
    What could be possibly wrong with it?
    I have also disable armoury crate in bios.
  • mon2
    • Dec 2019
    • 14254
    Test with a known good battery. They battery itself may be ample to stabilize this fault. The charging light flash means the battery is not being charged. The battery itself may be defective and is a common event after a period of time of charging / discharging cycles. Work with a vendor who will take the battery back if you decide to not keep it. Amazon?
    • 1centchips
      • Feb 2016
      • 41
      Thank you for your precious time and insight! The laptop exhibits same behavior when fully charged/ plugged in an outlet..
      • mon2
        • Dec 2019
        • 14254
        Are you powering this beast with the Asus official 240W/280W power adapter?
        Test this suggestion:
        https://rog-forum.asus.com/t5/gaming...v/td-p/1040270
        • 1centchips
          • Feb 2016
          • 41
          Yes, 280W that came with the laptop. The other thing I noticed was the laptop freezes way faster when Nvidia rtx 4060 is enabled (intel uhd disabled). Runs longer but eventually freezes with intel in use (rtx 4060 disabled).
          • mon2
            • Dec 2019
            • 14254
            Heating issue? Have good thermal paste on the GPU and CPU? Perhaps the original is caked up and is dry?
            • 1centchips
              • Feb 2016
              • 41
              I tried both off and moderate option in Link State power mgmt, no progress . I will order battery now.
              • 1centchips
                • Feb 2016
                • 41
                It's under extended warranty via third party. Was hesitant to remove the warranty void stickers all over the battery and heat sink LOL
                • 1centchips
                  • Feb 2016
                  • 41
                  In the bios utility the cpu is at 95 celcius.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    If it is under extended warranty,stop experimenting and log a call with the service provider. Will save a lot of money and time with zero headache.
                    • 1centchips
                      • Feb 2016
                      • 41
                      Tried new battery, no go
                      • 1centchips
                        • Feb 2016
                        • 41
                        I was trying to learn . But I understand the warranty part.
                        • YasaCh
                          Sony kdl 40p5500 red light keeps blinking 3 times
                          by YasaCh
                          Hello...
                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                          i opened the back cover no sign of damage on the powery suply or motherboard
                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                          07-07-2025, 11:53 AM
                        • Fergal22
                          Samsung UE40F5300AK blinking red light
                          by Fergal22
                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                          Any help would be appreciated...
                          02-02-2023, 09:19 AM
                        • matty24
                          Samsung UE50MU6172 - red light blinking
                          by matty24
                          Hello. I have problem with Samsung UE50MU6172.
                          TV won't turn on, red standby light is blinking.
                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                          Main board BN41-02568B (BN94-12530E)
                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                          03-02-2025, 08:57 AM
                        • norbiszoke
                          Samsung 50AU7172, only blinking red light
                          by norbiszoke
                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                          Regards, Norbert!...
                          04-17-2024, 06:54 AM
                        • ahoonid
                          820-00165 Random green light on charger
                          by ahoonid
                          Hey everyone,
                          I have a MacBook Air 2017 with a weird problem. The MacBook was totally dead at first and the culprit was the C7430 capacitor which was obvious upon initial inspection as it had a fracture on its surface.
                          The F7140 fuse was also blown so I changed them both. L7130 due to corrosion was also replaced. Now everything works again. Laptops turns on and everything seems reliable at this point.
                          The only issue that I'm afraid might bite me in the ass later is the magsafe light as it randomly changes light from orange to green while charging. Other times...
                          04-10-2024, 04:06 PM
