[help] 820-01958 dead: 20v not switching
  • phantomEVO
    • Mar 2013
    • 509
    Mon: I don't understand: Why should I put it in dfu? With its original rom it switch to 20v and try to boot!
    https://www.dropbox.com/scl/fi/mid7t...=qlwapj9j&dl=0
    it goes directly in dfu if I use a different rom taken from internet!
    AND IT STAYS AT 5V!
    • phantomEVO
      • Mar 2013
      • 509
      ok if i try to force it to dfu mode, it goes, but after a lot of time, it give me error 4042.....
      • phantomEVO
        • Mar 2013
        • 509
        mon?
        • phantomEVO
          • Mar 2013
          • 509
          is it possible that i'm missing some power rail? i'm missing P5VG3S_EN signal too
          • mon2
            • 14713
            Confirm each of the rails on u7800 noted on this webpage:
            https://repair.wiki/w/MacBook_Air_A2...VG3S_EN_repair
            • phantomEVO
              • Mar 2013
              • 509
              All present (bootlooping) except
              • PPVDDCPU_AWAKE ~ Normal voltage ~ 1.06v
              ​it is 0,75 boot looping
              • mon2
                • 14713
                Measure the resistance to ground level of:
                PPVCC_S0_CPU
                Repeat to test in diode mode. Post each measurement.
                • phantomEVO
                  • Mar 2013
                  • 509
                  96 oh, 0,236
                  • phantomEVO
                    • Mar 2013
                    • 509
                    at the beginning i had
                    5v on both ports, stable voltages but PP3V3_G3H unstable from 2,52 to 2,66 and ppbus_g3h@ 12,31
                    no change after reprogramming u4770 with a dump from internet
                    no change after changing u7650
                    PP3V3_G3H fixed at 3,3 and all voltages stable chaning u7800 but still 5v on both ports
                    device recognized in dfu...error Unexpected device state 'DFU' expected 'Recovery' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)
                    no dfu anymore after reflashing u4770 with my original backup
                    all voltages present but in loop. both ports now at 20v​
                    • phantomEVO
                      • Mar 2013
                      • 509
                      what do you think if i try to see if it goes to dfu erasing the eeprom?...i don't what else to do
                      • phantomEVO
                        • Mar 2013
                        • 509
                        just a an annotation....pp3v3_g3h_rtc is super stable, even ppbus_g3h
                        • mon2
                          • 14713
                          Review this thread:
                          https://boards.rossmanngroup.com/thr...roblems.61662/
                          • phantomEVO
                            • Mar 2013
                            • 509
                            the machine isn't in dfu mode....with original eeprom...
                            at this moment, all main voltages are present but goes to zero,
                            both ports are @ 20v
                            pp0v9_ssd not present. line is not shorted , is diode value is 0,480
                            • phantomEVO
                              • Mar 2013
                              • 509
                              with eeprom erased, always error 4014 (dfu logo disappear and reappear super fast then error 4014 (unexpected device status dfu expected recovery). all voltages STABLE
                              SAME IDENTIC VOLTAGE OF THE LINKE YOU GAVE ME:
                              PP1V2_AWAKE 1.2V
                              PP1V8_AWAKE 1.8V
                              PP3V3_AWAKE 3.3v
                              PPVDDCPU_AWAKE 0.755v
                              PPVDDCPUSRAM_AWAKE 0.802v
                              PP0V8_SLPS2R 0.800v
                              PP1V8_SLPS2R 1.8v
                              PP1V25_SLPS2R_SMC_AVREF 0.234v
                              PP1V1_SLPS2R 1.1v​
                              • mon2
                                • 14713
                                What about:
                                PPVCC_NAND_SSD0
                                PP0V9_SSD0_S4E0_VDD_PLL
                                PP1V8_VCCQIO_SSD0
                                PPVCCQ_ANI_SSD0
                                • phantomEVO
                                  • Mar 2013
                                  • 509
                                  Why don't you care about PP1V25_SLPS2R_SMC_AVREF ??? 0,234 exactly like the macbook in the post you have linked me?
                                  changed u4780, no i have 1,24v on PP1V25_SLPS2R_SMC_AVREF 0.234v!!
                                  eeprom repogrammed ! still no boot
                                  here power metere:
                                  https://www.dropbox.com/scl/fi/zgfty...=x6f01hvt&dl=0
                                  ppbus_g3h is "unstable" because it goes from 12,31 to 12,4 to 12,59 without any logic and come back to 12,31 (with charger and battery). with charger only, stable at 12,31
                                  all other voltages, still in loop: from the right voltage to 0
                                  • mon2
                                    • 14713
                                    Error 4014 is often NAND related so best to check their voltages are present and stable.
                                    Remove all power. Meter in resistance mode. What is the resistance measured across C7020? This is the battery current sense resistance path.
                                    • phantomEVO
                                      • Mar 2013
                                      • 509
                                      Don’t you remember that all voltages are unstable?
                                      • phantomEVO
                                        • Mar 2013
                                        • 509
                                        resistance measured across C7020​ is 2 ohm
                                        • mon2
                                          • 14713
                                          Good measurement. The battery charge leg is the proper resistance.
                                          Repeat for Vin into the PPBUS_G3H regulator (U7000) and measure across C7023. This should also be 2 ohms.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
