[help] 820-01958 dead: 20v not switching
  • mon2
    • 14713
    Review this power sequence chart which is applicable for your board:
    https://logi.wiki/images/6/6a/820-01...iagram_LO2.pdf
    • phantomEVO
      • Mar 2013
      • 509
      How? Ppbus_g3h is the first power rail…and it is not ok
      • mon2
        • 14713
        Attach a known good battery. What is the voltage then of PPBUS_G3H?
        • phantomEVO
          • Mar 2013
          • 509
          with battery and charger, ppbus_g3h is 11,5 and i have i have 20,27v @ 0,026 on both ports (i insert battery and then charger i have 5v, then i disconnect and reconnect the charger and i have 20v)
          with battery only, ppbu_g3h is 11,5v
          with charger only ppbus is 12,32v and i have 5v @ 0,046 on both ports
          • phantomEVO
            • Mar 2013
            • 509
            I've changed u7800 and now i have pp3v3_g3hot at 3,29! but ppbus_g3hot still at 12,31
            • phantomEVO
              • Mar 2013
              • 509
              u7800 ldo NOW:
              PP1V1_SLPS2R 1,1v
              PP1V8_SLPS2R 1,8v
              LDO_CORE 1,49v
              PP0V8_SLPS2R 0,79
              PP1V2_AWAKE 1,19
              PMU_LDO3_OUT 1,95v​
              basic voltahe on u7650
              pin 23, 22, 12, 13, 29, 21, 4.
              12,31
              0v
              0
              0v
              0v
              0v
              • phantomEVO
                • Mar 2013
                • 509
                ok now it is in dfu: can i try to fix it without losing data?
                i can choose between
                restore
                update
                prepare
                reactive
                initialize​
                • mon2
                  • 14713
                  No revive? Revive will be without user data loss.
                  Actions > Advanced > Revive Device
                  https://www.hoxtonmacs.co.uk/blogs/n...DDoKIrwjcJoOSX
                  • phantomEVO
                    • Mar 2013
                    • 509
                    i have translated from my language...i think revive is reactive
                    • phantomEVO
                      • Mar 2013
                      • 509
                      Unexpected device state 'DFU' expected 'Recovery' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014
                      • phantomEVO
                        • Mar 2013
                        • 509
                        PP1V2_AWAKE 1.2V
                        PP1V8_AWAKE 1.8V
                        PP3V3_AWAKE 3.3v
                        PPVDDCPU_AWAKE 0.755v
                        PPVDDCPUSRAM_AWAKE 0.802v
                        PP0V8_SLPS2R 0.800v
                        PP1V8_SLPS2R 1.8v
                        PP1V25_SLPS2R_SMC_AVREF1.25
                        PP1V1_SLPS2R 1.1v​
                        • phantomEVO
                          • Mar 2013
                          • 509
                          i have the error with battery only, with power supply only with both connected
                          • phantomEVO
                            • Mar 2013
                            • 509
                            could it be possible because of having tbt reprogrammed some post before?
                            • phantomEVO
                              • Mar 2013
                              • 509
                              PP0V9_SSD0 but it is not shorted
                              • mon2
                                • 14713
                                What is the exact voltage to ground of PP0V9_SSD0?
                                Yes, try to reflash the TBT rom directly like before. Does that allow for this to work? Good job on the PMU replacement - you have more (bga) balls than I.
                                • phantomEVO
                                  • Mar 2013
                                  • 509
                                  PP0V9_SSD0 is 0v
                                  i have no problem replacing even smaller chip....i would like to be good like you with the theory!!!!
                                  SO DO YOU THINK THAT COULD BE A TBT ROM PROBLEM??? are you sure??? because reprogram it is a pain in the ass
                                  • mon2
                                    • 14713
                                    Wait on the TBT rom for now. Review and consider the points of interest from this thread:
                                    https://repair.wiki/w/MacBook_Pro_A2..._at_20V_repair
                                    Report any mismatches. You are to review the SSD rails in diode mode, etc. since you have 0 volts.
                                    • phantomEVO
                                      • Mar 2013
                                      • 509
                                      this is a totally different machine....i have not the same power rails...and i have 20v only if i connect battert power supply
                                      • mon2
                                        • 14713
                                        Yes, I know. Just review the SSD0 details. Using the same posted values in diode mode, etc. Note the resistance they are mentioning in the article. Would you have similar measurements?
                                        • phantomEVO
                                          • Mar 2013
                                          • 509
                                          PP0v9_SSD0 is ok
                                          there is no PP2v5 rail
                                          and about PP1v8_SSD0
                                          i have 4 differret rail and according to open board data
                                          PP1V8_SSD0_S4E1_PCI_AVDD_H
                                          PP1V8_SSD0_S4E1_AVDD18_PLL
                                          PP1V8_SSD0_S4E0_PCI_AVDD_H
                                          PP1V8_SSD0_S4E0_AVDD18_PLL
                                          are all ok​
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
