[help] 820-01958 dead: 20v not switching
  • phantomEVO
    • Mar 2013
    • 509
    yes 2 ohm...i'm going to give up.....why this motherf*ckers voltages are in loop?? and why are them stable if in dfu?
    • phantomEVO
      • Mar 2013
      • 509
      so is it normal that i have not nand voltages?
      • phantomEVO
        • Mar 2013
        • 509
        i understand, but i dont' want to give up....maybe i should open a new thread and write " i don't know the history of this devic: it switch to 20v but it seems in boot loop: what can i check"
        maybe restart from the beginning would be usefull...
        for example i think i MUST HAVE some power rails before to boot...is it possible that it does'nt boot because i miss some rails?!??!? is it possible that i miss for example ssd rails???
        i think i should start from:
        PPVCC_NAND_SSD0 (VCC for both nands)
        right?
        created by u9060...
        it is a little bit difficult for me to undertstand how u9060 works...i should have
        PPBUS_G3H_SSD0 to have it working right?​
        • mon2
          • 14713
          What is the resistance to ground of PPVCC_NAND_SSD0?
          If the resistance is low then the NAND is defective. Without a working NAND, you cannot complete the DFU. With a defective NAND with a low resistance, the power rail will not operate properly. Each SSD0 power rail needs to be inspected for the same conditions.
          • phantomEVO
            • Mar 2013
            • 509
            PPBUS_G3H_SSD0 is 12,32
            pvcssd0_en is 0v
            pvcssd_avin is 12,32
            PPVCC_NAND_SSD0​ is 19k
            0,346 in diode mode
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
              I was working on this CNC machine today found no keyboard functioning no control relay powering on
              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
              Found shorted diodes on main controller relays there are 3 of them that...
              01-07-2023, 05:43 PM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
              After all of...
              07-13-2024, 08:14 PM
