[REQUEST] Tuf 517Z not turn on.
  • kurtspirit
    • Feb 2019
    • 112
    • France
    I am looking for this component please : the mark is 5X = 9C 909
    The PC is a TUF517Z and the fault is: no boot.
    The charge seems ok although the orange light sometimes starts flashing but no boot.
    This happened after an object fell on it.
    I put the CM under a thermal camera and this famous component directly rises in temperature. So I assume that it is responsible for something.
    Do you have any idea what it could be please?
    Thank you.​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    RT6575DGQW
    Measure resistance to GND on pin3 and 13 of this IC without any power source attached.
    • kurtspirit
      • Feb 2019
      • 112
      • France
      RT6575DGQW
      Thank you.
      Here are results :
      Pin 3 : 8.7 kohm
      Pin 13 : 10 kohm
      I followed the datasheet to find the pins, at least, the direction to read them. If I'm not mistaken, they are in the "counter-clockwise" direction but if I reversed it, then here is the result:
      Pin 3 : 1.60 kohm
      Pin 13 : 0.01 ohm.
      To be as clear as possible (I apologize for my low level of knowledge), I add to the message a photo with the measurements indicated according to the pins.
      Thanks again.​
      • mon2
        • Dec 2019
        • 14355
        Yes, to be measured and counting in the counter clockwise direction. Dot is pin #1 and will be to the left of this marking.
        • kurtspirit
          • Feb 2019
          • 112
          • France
          Ok, i knew for the dot but not the side
          So , pin 3 is 1.60kohm and 13 : 0.01ohm.
          Thanks for sharing your knowledges and your help.
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • Luke Anders
            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
            by Luke Anders
            A few details about the laptop itself:
            Name: Lenovo Legion 5
            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
            BIOS Version: GKCN60WW
            EC Version: GKEC65WW
            Serial Number: PF39AQ7Z
            Board Model: NM-D562 Rev 3.0
            RAM: 16GB Installed, DDR4 (brand new)
            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
            I bought this laptop recently from eBay as a faulty device....
            10-12-2024, 05:13 AM
          • LegendBR
            Samsung 48J6400 fail to turn on, loop boot
            by LegendBR
            My Samsung 48J6400 started behaving strangely: it would take a hard time to turn on (would cycle from on and off a few times before I got it to stay on), until one day it decided not to turn on, just flashed me the power led (blinked twice briefly for 5 times). So I decided to take it to the repair store.
            Before I took the TV to the repair shop, I was thinking the problem was work the PSU, since the TV was having a hard time to boot prior to not booting at all. But the diagnosis was that the culprit was the panel, and it would cost a new TV to repair it.
            The thing...
            12-21-2017, 11:12 PM
