Need help hp 725 g3 liquid damage
  • azozexd
    • Sep 2019
    • 50
    • Maroc
    Hello freind i have hp elitebook 725 g3 White liquide damage
    after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
    could some one tell me the value of this resistor
    Thank you
    • 21467
    Can you not Type out the motherboard model number. Have you checked if there is a schematic/boardview available
    • azozexd
      • Sep 2019
      • 50
      • Maroc
      Yes i search for schematic not available
      model of board: LADYLUCK-6050A2725101-MB-A01
      • mon2
        • Dec 2019
        • 14570
        See attached. Is that a defect in the surface of the EC chip? If yes, this EC is very likely to be defective.
        • azozexd
          • Sep 2019
          • 50
          • Maroc
          Thank you for helping no its just rusin not clean
          There is no chort in motherboard just wather damage
          this resistor i want to find his valeu to replace it
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Since no info is available check the resistor is connected to which IC. to me it seems like charging IC REGN pin. You can then proceed to similar schematic with same charging IC to found the value of resistor.
            • azozexd
              • Sep 2019
              • 50
              • Maroc
              Thank you yes i search for schematic no way
              if somme one has the same motherboard it can help me
              • mon2
                • Dec 2019
                • 14570
                Carefully inspect each square chip on the board for their topside markings. Hunt for one with 'BQ' or 'TI' in the part number. Post clear pics of the chip. This may be your charger IC on the logic board. This part should be close to where the power adapter mates to the logic board.
                • azozexd
                  • Sep 2019
                  • 50
                  • Maroc
                  Thank you for respond
                  yes its (BQ) charging ic
                  laptop its good after cleaning
                  But this this resistor is damage
                  I don't Know his valeu i want to replace it
                  i think 10k resistor butte i'm not sur
                  • mon2
                    • Dec 2019
                    • 14570
                    Trace the pin which connects to this resistor and charger ic. Then review sample schematics that use this charger ic to learn the resistor value.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      What can one do if someone dont follow it up. I already suggested the way out.You just need to put a little effort on your own.
                      Everytime there cant be a picture perfect readymade solution available.
                      Sorry if my harsh comments hurts you.
                      PS: Re-read my post#6
                      • azozexd
                        • Sep 2019
                        • 50
                        • Maroc
                        yes of course i will try in moterboard white the same ic
                        thank you
                        • azozexd
                          • Sep 2019
                          • 50
                          • Maroc
                          Thank you i will try
                          • azozexd
                            • Sep 2019
                            • 50
                            • Maroc
                            Thanks to all friend
                            I search for bq24780s schematic and i find resistor valeu its 100k resistor
                            i put 100k resistor its in (ACDET) pin
                            no power the mosfet has no signal bq24780s to switch the 19v i make bridge wire and BOOM🔥 laptop turne on butte not charging battrie after i replace bq24780s and BOOM🔥 again😅 and laptop start another life thanx to ALL
                            • mon2
                              A1466 Macbook Air (Liquid damage repair)
                              by mon2
                              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                              Macbook AIR Model A1466 Diagnostic 09-01-2021
                              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                              Problems & Resolutions
                              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                              09-01-2021, 09:31 AM
                            • rilley
                              MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                              by rilley
                              I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                              I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                              My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                              And the resistor L4004 is literally burned.
                              From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                              07-10-2024, 01:57 AM
                            • Jenzo
                              MacBook A1989 overheating after liquid damage
                              by Jenzo
                              Hey everyone,
                              Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                              I can't figure out how...
                              05-13-2023, 07:58 AM
                            • mitchw
                              MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                              by mitchw
                              Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                              It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                              I quickly took it apart and washed the liquid residue off the mainboard.
                              The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                              The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                              Now the laptop...
                              07-16-2025, 07:55 AM
                            • larrysito111
                              dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                              by larrysito111
                              got here a liquid damaged alienware
                              the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                              so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                              so with the usb-c external monitor is getting to bios and OS
                              otherwise not
                              so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                              but still not the internal monitor
                              (tested 3V and 5V going to the...
                              06-12-2025, 04:16 PM
